Rectifier Regulator Replacement FH 0012aa
kb0ou
Post by kb0ou »
This is a project to replace the Rectifier and Regulator in the 12 volt charging system on my 79 Goldwing.
The main reason to change it is to remove the Regulator to provide more room for Electronic Fuel Injection Items under the Left side of the Faux Gas Tank. I will be mounting my computer (MicroSquirt) about where the Regulator used to be.
Also the new R/R is more efficient than the old Honda system due to more efficient diodes that are available today that were not around back in 1979.
Here is a link to my EFI project write up here on NGW...........
http://ngwclub.com/forum/viewtopic.php?f=47&t=31474
This is the kit I ordered from Ebay...... url .............
http://cgi.ebay.com/ebaymotors/SHINDENG ... 53e70b7658
1979 Goldwing gave it away... :(
kb0ou
Re: Rectifier Regulator Replacement FH 0012aa
Post by kb0ou »
Here is a drawing with demensions of the R/R
Old Fogey
Post by Old Fogey »
An eBay address would be good, please.
kb0ou
Post by kb0ou »
Here is a pic with original Rectifier.............
kb0ou
Post by kb0ou »
Removing the battery box.....
kb0ou
Post by kb0ou »
the old rectifier out and "unplugged"...................
kb0ou
Post by kb0ou »
The old Regulator out.................
kb0ou
Post by kb0ou »
This is where the Regulator used to be.....
The future home of a MicroSquirt EFI computer,,, part of the reason I am doing this job,, make more room for Electronics.....
Note; The black wire on the Regulator plug is switched 12 volts from the Ignition Switch, it will be useful in the future to hook up to the MicroSquirt computer...
kb0ou
Post by kb0ou »
Old Rectifier and Battery Box.....
New Rectifier/Regulator mounted to Battery Box..........
The Rectifier mount that is on the Left side of the Batt box was removed, trimmed of the mount for the ignition condensers and remounted but turned 90 degrees.
The bolt holes/nuts for the old rectifier lined up perfectly for the new one.
I did have to use some spacers on the original bolts as they were a little long,, spacers are large nuts.
Hey, it works............
kb0ou
Post by kb0ou »
Remounting Battery box with new R/R......................
Note; The Ebay kit comes with the plugs that plug into the R/R, they are pretty nice plugs, one for the Stator wires (3 Yellow) and one plug for hooking up to the Battery, with 30 amp fuse.
Instructions are good, make sure you solder all connections good.
I did cap the two red wires to the Left that used to go from the Rectifier to the Battery by way of the Starter Relay. They are still connected on the Relay side, I put some butt connectors on the wires. Who knows I might use them for something sometime??
And I did not want them to go to ground and do some arcing and sparking.
The old yellow wires hanging and green wires are not hot. The greens are Ground, I may tie them to a good ground if neccessary.
kb0ou
Post by kb0ou »
It works, this is at Idle, Never had 14.5 at idle before!!!!.....................
Pic of tachometer during volt test...........
So, I call this a success, I have more room for my EFI project and a charging system that works better
A Win/Win situation!!!!
kb0ou
Post by kb0ou »
Old Fogey,
I inserted the ebay url above the first pic,, but here it is also.............
A bit costly at $119.00 US but even the cheap stuff is expensive now days!!!!!!!!!!!!!!
John kb0ou :crosso
Toehead
Post by Toehead »
It's nice not to shunt 300 W to the case all the time for no particular good reason. Yay for PWM of MOSFETS.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
Old Fogey
Post by Old Fogey »
kb0ou wrote:Old Fogey,
John kb0ou :crosso
Sorry John,
It's the old age thing again!
shieldsm
Post by shieldsm »
I am at the point in my rebuild to do this mod but I have a couple questions:
1) What should I do with the black wire that came of the regulator? Just cap it off?
2) I also have 2 red/white wires that went to the old rectifier, and the other end (one wire that ended up at the starter solinoid. So you just capped those off as well? Why connect the other end to the starter solinoid?
3) I have 3 to 4 green wires that went to the old rectifier. Should I connect all these to a ground or just cap them off?
4) As far as the in line fuse, this can be used instead of the old fuse setup?
Thanks if advance for clarifing
