Look what I got from Sabre Cycles buyer beware
- groupus
- Location: Lancaster Pa, USA, Earth, Solar System, Milky Way
A headache.
A very big headache.
This belt is a year and a half old with 4,800 miles on it. I was slowing for a turn and down shifting when it happened. Pulled the clutch in and it just died because the left cam was no longer closing the points. I'm hoping for minimal damage since i kept the clutch in and and didn't force it. The engine is still able to turn over without interference.
What is the least intrusive way to see if the valves may have suffered damage? I do not have an air compressor to pressure test the different valve positions to see if there is a leak.
Needless to say, I am livid at SC, but there is nothing I can do about it now. Next time I will buy quality.
Faster, faster, faster, until the thrill of speed overcomes the fear of death. ~Hunter Thompson
every now and then, when things are not going to well in the shop, i ask myself why i do it. and the answer is that riding is good....but time in the shop is also good. - CYBORG
78 gl1000 cafe build: http://ngwclub.com/forum/viewtopic.php?f=30&t=51461
79 full fairing - current status: Haunted http://www.ngwclub.com/forum/viewtopic.php?f=1&t=60334
- Placerville
Re: Look what I got from Sabre Cycles
First, I'm very sorry this has happened and I hope your bike hasn't suffered any damage. (BTW, good clutch move.) Second, what brand are those belts? Can you tell?
- RB
compression check..all plugs out, throttle full open, crank her over with compression gauge in each cylinder one at a time..gauge?? $15 at most parts stores.
You could replace the belts then pull the valve covers and check the tappet gaps if they are still right..then the valves are working and nothing was bent. If bent the setting will be off and not change as the valve will be stuck open or shut.
But I'd turn her over by hand first several times to be sure your valves aren't hitting..if they are not you were very lucky!!!
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- brokentoe
That stinks. Sorry for your bad experience.
Faith, Family and Friends
'75 GL1000 (Feb 2012 BOTM)
2014 Softail Deluxe
First Fire on Youtube!
2014 Softail Deluxe
- groupus
The belts are Baracuda Bike Parts, made in China
RB, i'm guessing I will need to replace the belts to do a compression check? (I still have the original belts as spares) Thanks for the suggestions, those seem like pretty easy ways to check; the last thing I wanted was to start ripping the head off.
Also, I cranked the engine over several times trying to start it when I first thought it was an electrical problem. it turned over easily with no odd noise. So I'm trying to figure out if that is a good or bad thing
Could be that there is no interference; could mean that the valves have been bent out of the way. I have a hard time believing that all 4 valves have come to rest in a safe place, but I can hope.
Updates to follow
Updates to follow
- Recycled Roadkill
Considering where you sit right now the easiest thing you could do is replace that timing belt as you said, and check compression. it's worth seeing what you get with very little more work at this point.groupus wrote:The belts are Baracuda Bike Parts, made in China![]()
Also, I cranked the engine over several times trying to start it when I first thought it was an electrical problem. it turned over easily with no odd noise. So I'm trying to figure out if that is a good or bad thingCould be that there is no interference; could mean that the valves have been bent out of the way. I have a hard time believing that all 4 valves have come to rest in a safe place, but I can hope.
Updates to follow
Bob Gill
'77 Honda GL 1000 Black Mamba (Sold)
- Toehead
Sorry this happened to you.
Get the crank aligned with the T1 mark, then rotate counterclockwise by 90 degrees. You can then rotate the cam on the broken side without fear of hitting anything with the valves. Get it lined up to the timing mark, rotate back to T1, and throw a belt on there. Then a quick compression check. With luck you will be fine. Even if you have a bent valve, rebuilding the head isn't too hard, just need a lot of time and some money for the gaskets and o-rings.
Then, order belts from cascade cycle. Probably cheaper as well!
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
- NewWinger
Sorry for your trouble.
I think I bought my new belts from Sabre cycle aswell.
The good news is that I haven't put the engine into service yet.
Will check my parts reciepts as soon as I get home. If they did come from Sabre, I'm pullin em and going to cascade
for a new set.
Good luck!
for a new set.
Good luck!
Kenny
Illegitimi non carborundum
'77 GL1000 my first bike @58
- Recycled Roadkill
Yet another black eye for Saber Cycles.
Bob Gill
- NewWinger
Needless to say, I'm going to get another set, probably the Gates set.
Thanks for warning me. I'm new and haven't put the engine in her yet. You probably save me a lot of heart burn!
Kenny
Kenny
- groupus
NewWinger, you might be ok with the belts from Sabre Cycles if you are also replacing the tensioner too. You can see in my pic that the one side of the belt is worn heavily. At the time I replaced them, the tensioner seemed ok, but it was of unknown age. That's my mistake for not doing it right, and I believe that that is heavily responsible for their early failure. I also ride my bike hard. It is stripped down and I love tearing around and reving it out. I also did a burnout competition at Carlisle bike week a few weekends ago
If ride your bike like a normal human and plan on replacing the belts BEFORE the recommended period, they should last 1000s of miles. It's up to you, but my bike has seen more abuse than most. Just my $0.02.
- NewWinger
groupus,
I hear you and thanks, but I all ready ordered a set of gates. I have never owned a bike before and this project is what I call "Cycletheropy".
I am very cautious and had I known the SC belts were Chinese, I would never of bought them. As it is I did replace the tensioners while I was at it since their age
and condition were unknown. I will likely rider her like the Old grampa that I am so now I am doublely confident my preventative maintenance will stand me in good stead. BTW last time I rode a bike was when I was only 19 and I have a grand total of about 8 hrs time riding in my life. I'm 58 now and "Lookin for adventure."
Gonna take the rider's safety course before I hit the road...in the mean time I have a bike to put together...77 GL1000.
You can pay a therapist or have fun hobbies. I prefer tinkering.
All the best,
Kenny
All the best,
Kenny
Kenny
First you say this.................
"Needless to say, I am livid at SC, but there is nothing I can do about it now. Next time I will buy quality."
Then this..................
Believe me, I would never stand up for SC. But you can't talk a place down for their product and then say that you may have added to the failure.groupus wrote:NewWinger, you might be ok with the belts from Sabre Cycles if you are also replacing the tensioner too. You can see in my pic that the one side of the belt is worn heavily. At the time I replaced them, the tensioner seemed ok, but it was of unknown age. That's my mistake for not doing it right, and I believe that that is heavily responsible for their early failure. I also ride my bike hard. It is stripped down and I love tearing around and reving it out. I also did a burnout competition at Carlisle bike week a few weekends ago![]()
backwoodz
- Zinc Member
Sorry to hear man but why would anyone buy chinese belts when you can buy gates for $15 each?
1981 GL1100
- Sagebrush
Not to hijack this thread but given SC's reputation I would never buy or use anything from them.
