Homemade temperature and fuel gauges?
- Toehead
Re: Homemade temperature and fuel gauges?
That looks great. THe hysteresis is very well done.
Are you having fun yet ?
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
I took a pretty long break from the gauge project. I found a salvage set of gauges and indicator housing, on HIGHSHIPPINGCOST BAY. Figured I had better get a backup setup incase I don't get the custom setup done in time for riding season. I know I would like to clean up the handlebar area. Probably just run one gauge. Most likely keep the speedometer the small bar graphs and all the led dots as indicators. I just imagined my speedometer as a bar graph. So now I may be off on another tangent...... this project may never end.
Failure is fourplay for success!
Did a bunch of sauldering tonight. Partway done getting the components onto some boards.
- Toehead
Looking good. Are all those trim pots for adjusting you resistance levels on the volage divider?
1980 CB750C (sold)
1980 CB750C (sold)
Yes. It's crude. I'm pretty sure it doesn't follow the examples from the manufacturer. But I needed something I could recalibrate when it's on the bike. For that matter the v ref and v out are both connected and going to the last two resistors, they are chained out to ground in a way that doesn't make sense to me, but it works. I'm not so accurate with the maths so I need something where I can dial in the lights until they line up where I want them to. The thermostat housing needs seals replaced, so I might take out the temp sensor and boil it while dialing in the gauge.
Wow. Did I ever give up on this project. If I move this any further it will probably be completed with a small Arduino and some code.
- Toehead
May be easier
You got pretty far though!
1980 CB750C (sold)
1980 CB750C (sold)
Digging up a dead thread due to search finding it. I'm looking to replace the fuel meter on one of my GL1000s with an LED bar graph. Will probably run on 12 volts as I will be replacing the temp gauge with an off-the-shelf unit (I've already made an adapter for its sensor). Plan to use the original level sender and ~250 ohms to replace the gauge resistance (generating a volgage difference at the junction). I've built LED VU meters years (decades) ago, and plan to use LM339 comparators with calibration pots to set each threshold as gas is added to the tank. I'll make up a dummy sender for initial testing. I'll start a new thread on it soon.
- Chris in TN
That's an interesting project Pid.
Chris
Current fleet:
1976 GL1000, 1978 GS1000E, 1979 GS1000S, 1981 CM400C,
1986 RG500G, 1988 R100RS, 1991 K100RS, 1997 GSF1200
Current fleet:
- 544 Views
Last post by Oldboy
- 3 Replies
- 213 Views
Last post by BlueThunder
- 4 Replies
- 175 Views
- 7 Replies
- 407 Views
Last post by Sidecar Bob
