eBay master cylinder rebuild kits
- tlbranth
Re: eBay master cylinder rebuild kits
I'm talking about hi/low beam & turn signals
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- propav8r
Why on earth would a clutch perch include those?tlbranth wrote:I'm talking about hi/low beam & turn signals
- jdvorchak
Usually only the clutch pull gear switch is in the perch. Those other switches are on the left switch cover. I think you are confusing a clutch perch with the left switch cover.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
My 1976 has switches ( headlight, hi-lo beams, turn signals, and horn) and clutch perch built in one assembly. My 1978 and 1979 have seperate clutch perches and switch assemblies.
1976 gl1000 sulfur yellow
1977 GL1000
1978 Gl1000
1998 Valkyrie Tourer
1977 GL1000
1978 Gl1000
- flyin900
+1 On the above!
There was a model design change over that the early Wings did around 1976 from the combination design that included the whole electrical switching/clutch perch to a separate design that was supposed to be superior to the all in one design. WingOvations covers it in his technical section on his site that the separately designed clutch perch was supposed to work better with the clutch cable pull.
My 1976 has the redesigned dual set up; yet when I bought a 1976 set of bars with switches for spare parts they were the combination design.
Current Bikes:
- tomk1960
The company that manufactures the kits for K&L also supplies the manufacturers directly. The kits are high quality - I've been using and selling them for years.flyin900 wrote:Not sure what brand of kit you are referencing here. I have used the K&L aftermarket rebuild kits a number of times on various different bikes and had no problem with the quality. I believe they are a Japanese branded manufacturer.
1986 VFR750F Interceptor
1978 Honda GL1000
1978 Honda GL1000
- tlbranth
Ax Hondapropav8r wrote:Why on earth would a clutch perch include those?tlbranth wrote:I'm talking about hi/low beam & turn signals
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- tlbranth
Willie & Flyin - thanks for the info on the design change. If I use the Chinesium Fluoride lever set, I'll look for a used '77 switch assembly. Apparently the controls work well but switches? Not so sure.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Would this master cylinder with the16mm bore be considered a performance up grade on my 1981 GL1100?
- 10 Replies
- 536 Views
Last post by SoyBoySigh
- 22 Replies
- 554 Views
Last post by jdvorchak
- 3 Replies
- 232 Views
Last post by west756
- 10 Replies
- 487 Views
Last post by Fetasigma
