I loaned my Gold Wing 20 cents, and it gave me better braking!
To take up the free play in my front brake lever, a dime seemed it would fit well as a shim.
It did!
I used two.
This spaced my lever out further for my big hands, and keeps my lever from coming all the way back to my third and fourth fingers during hard two-finger braking.
Scott
It did!
I used two.
Scott
- IMG_0253.JPG (162.29 KiB) Viewed 411 times
- IMG_0255.JPG (224.69 KiB) Viewed 411 times
Ride like you mean it.
- salukispeed
Re: I loaned my Gold Wing 20 cents, and it gave me better braking!
I like it and easier than some of the alternatives like adjustable levers or
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
someone has to say it...so now your wing stops on a dime!
- brianinpa
I bought a 1200 parts bike that had a dime in the front MC inspection window. Who would have thought there was more than one meaning to stopping on a dime!
Brian
ADC(AW) - US Navy Retired 1983-2003
If you aren't having fun doing it, find something else to do.
1984 Standard - 18,000 miles - Naked... the way it should be
1987 Interstate - 62,000 miles - Resurrected from the rust bucket
- jdvorchak
Excellent idea and only costs 20 cents!
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
PLUS, I'll never really be broke!
I can go to my bike if I REALLY need money!
Haha!
Haha!
- RIP: cookie
Clever ....
While bleeding my front brakes, I remembered reading this helpfulinfo on here...Made all the difference in the world. Thanks for the tip!
1976 gl1000
- BlueThunder
All jokes aside... your brake lever is worn beyond normal serviceable limits. Is it safe with the dimes? Don't know, but when it comes to my life and safety (and brakes are right up there along with tires), I would replace it.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- jdvorchak
Almost looks like an aftermarket brake lever. As long as your front brakes are not mushy the adjustment you made should be safe. I two finger all the time and never had an issue with the brake lever coming back too far unless there was still air in the lines somewhere.
2021 HD Triglide
John
2021 HD Triglide
John
- Graham Cracker
Improvising at its best
Mark
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
- WingMan71
I read this thread with great interest, since I have the same situation on my new-to-me '76 GL1000 LTD.jdvorchak wrote:Almost looks like an aftermarket brake lever. As long as your front brakes are not mushy the adjustment you made should be safe. I two finger all the time and never had an issue with the brake lever coming back too far unless there was still air in the lines somewhere.
I just rebuilt both front brakes with new seals and new pistons last week and flushed the system with new fluid. Brakes work absolutely great now, but that slop in the lever before it hits the master cylinder activating shaft is still there!
I know that I have original brake and clutch levers since they both still have that plastic sleeve on them that has now turned a bit yellow. So, those are original. What I can't confirm to be original is the front brake master cylinder assembly. In fact, I suspect that it's not original because of its color. It is not flat black like any original I've seen on old Japanese bikes, but rather it's kind of a dark gray or pewter color, the same color as the OP's master cylinder.
If it is, in fact, a replacement master cylinder assembly, that just might explain the "take-up" in the brake lever before it hits the MC activation shaft.
Whatever the case, I'm gonna put 20 cents into mine as well and "fix" it.
Thanks for the tip!
1983 GL650 Silver Wing Interstate
2006 Gold Wing GL1800 CSC Trike
1982 CB750 Custom
1976 Gold Wing GL1000 LTD - SOLD
1987 Gold Wing GL1200A Aspencade - SOLD
U.S. Navy SWO 1967-1976
1982 CB750 Custom
Good chance it is original. But over time they fade to look as you describe. My LTD is the same way.WingMan71 wrote:snip............ I suspect that it's not original because of its color. It is not flat black like any original I've seen on old Japanese bikes, but rather it's kind of a dark gray or pewter color, the same color as the OP's master cylinder.
- BigBrian27
This is a popular mod with the KLR crowd. Did it to my 07. Works well.
1975 Honda GL1000 Goldwing
1992 Kawasaki Concours ZG1000
Solid rotors suck! I have the PDF for the rotor drilling template, PM me if you would like a copy.
- WingMan71
Wonder what GLUE people are using to hold the dime in place?
Super Glue is not a good idea since it's NOT waterproof!
(Made that mistake once before and lost the part when it rained.)
So, what glue? Epoxy?
1982 CB750 Custom
1982 CB750 Custom
