I replaced my front master cylinder with no bleeding necessary!
Hi Fellas,
I ordered a smaller-bore front brake master to compliment my new stainless brake lines and improve my braking performance.
It's meant for a Kawasaki Z1. Out of respect for what Mr. Honda did with this masterpiece, I reused the Honda reservoir cap!
I had already replaced the lines, and I got such a solid, air-free bleed, I was wondering if I'd be able to replicate that when I replaced the master cylinder.
Then I had a brainstorm! I unbolted both front brake calipers and took them off the brake discs so I could squeeze the brake pads together and pump all my fluid down in to the calipers. Then I soaked up the remaining fluid in the reservoir, replaced the master cylinder and pressed apart the brake pads, pumping about half an inch of air-free fluid back up into the new empty master cylinder and reservoir!
It worked!
All I had to do was top off the brake reservoir, and I still had the super-firm brake feel I had before!
I'm a genius!
Well, I feel like one, anyway! I'm sure someone has thought of this before, but I've never heard of it.
I hope someone else can use it.
One caution, though, make sure the reservoir cap is on when you spread the pads apart. If not, even if you spread them slowly, the brake fluid will shoot to the garage ceiling!
Scott
It worked!
I'm a genius!
Scott
Ride like you mean it.
Re: I replaced my front master cylinder with no bleeding necessary!
cool idea..
I'm assuming the M/C that your replacing is empty when you un-bolt the brake line from it ? Then you re-attach the brake line to the "New" empty M/C that is empty ?
Forcing the 2 Calipers with the brake pads touching to open again would force any trapped air that would enter the brake line at the M/C when it was removed ?
Yep!
Much of the fluid was pumped down into the calipers when they were removed from the disks and then pumped closed.
I soaked up the rest out of the reservoir with a rag before removing the old master cylinder.
Then when I attached the new master cylinder and spread the pads apart, that returned much of the fluid to the new master cylinder. All I had to do was top it off and the lines were still air free!
Scott
Scott
- Sugs
I did the same thing when I replaced my master cylinder with one from a cbr f4i. Worked great. Wish it was going to be that easy when I rebuild my calipers.
_______________________
'79 Honda GL1000 Goldwing
Cool, thanks for the tip.
How difficult was it to spread the brake pads apart when you pumped the brake lever to where the pads were touching when the calipers were removed from the forks ? Weren't you afraid that pushing the pad out that far that the piston in the caliper would move past the seal in the caliper bore ?
With the pads in there it would be about impossible to push the piston out that far. They are pretty long.GLDCW wrote:How difficult was it to spread the brake pads apart when you pumped the brake lever to where the pads were touching when the calipers were removed from the forks ? Weren't you afraid that pushing the pad out that far that the piston in the caliper would move past the seal in the caliper bore ?
GLDCW-
I'm not sure how close I was to pushing the caliper pistons too far, but I had no problems after pushing them back in.
Just got a break in the storms of the century here in SoCal and took a short test ride.
The brakes feel great!
Scott
Scott
BigSherm, Worked like a Charm Peformed procedure as outlined above and re-attached the brake line on New M/C. Brake pads were very easy to squeeze by hand back into calipers to provide enough gap to slide over brake rotors. Topped off M/C with brake fluid and pumped the brake lever several times to regain brake lever travel. Smaller bore M/C ( 5/8" ) feels so much better with less brake lever travel Look forward to riding the bike soon and see the difference in brake performance Thanks again for the TIP
You're welcome!
It worked so well, and saved so much hassle, I'm still surprised I've never heard of this before.
Scott
Scott
- jdvorchak
I would be tempted to just put a big flat blade screwdriver, or any robust steel plate, between the pads and then pump it up. In my mind that would cause less marring to the pads when it's time to push them back into the calipers. I keep my old worn out pads and use them when I want to pry against a pad to compress the piston.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- warhead_71
Great idea. Thanks for sharing!
http://www.ebay.com/itm/401043758059?_t ... EBIDX%3AIT
This is the Link to the M/C that I used on my 75' Wing. Finish is real Nice and after installing, brake lever feels really good. Look forward riding it tomorrow
I just received my SS 3-Line front brake line kit from Galfer. Very Nice Kit and extremely Fast delivery !
I'm wondering if removing the front calipers and squeezing the brake pads together would ease the installation of the new brake lines without dealing with the laborious bleeding method ?
If not, any other Tips ?
