Wondering is wires like this would work. Love the look.
And can I reuse the spark ends from my old cables (that worked fine)
https://www.ebay.ca/itm/360870268333
If I can't reuse the ends what else would I need to hook to my stock ignition?
Spark plug wires
Spark plug wires
1980 GL1100I (parts)
1978 GL1000
"I Have No Idea What I Am Doing."
1978 GL1000
- flyin900
Re: Spark plug wires
That wire will work fine although I question reusing the old plug caps. New caps are not too expensive and since they are a resistor type even your old ones have resistors, it is worth considering replacement. I have seen these fail as they age especially the internal resistor.
The new NGK caps will also look good on your new wires.
Current Bikes:
- Mike-C
Hello Pizza;
I did a similar mod to my Wing, and you are right the OE plug caps will work just fine. I used 8MM Accel yellow silicone wires. Just make sure your new wires are not resistance wires. I found that if the plug caps have resistors, the wires have resistance, and if the plugs have resistance that is far too much resistance.
Mike Coleman
'84 Wing-Lite (ex-Aspencade)
'84 un-Terstate
Mike Coleman
'84 un-Terstate
Mike Coleman
North Lancaster, Ontario
Canada
Canada
- 281 Views
Last post by jdvorchak
- 630 Views
Last post by Track T 2411
- 12 Replies
- 466 Views
Last post by Toehead
- 4 Replies
- 267 Views
Last post by Steve81GL1100
- 4 Replies
- 330 Views
Last post by Sidecar Bob
