forks
- Zinc Member
forks
Guys, just finished getting my 78 running...and am noticing the front forks seem to pogo some, ie they chatter fore aft a bit instead of up and down as they should, i did use atf instead of regular fork oil could that be it,, also adjusted the head bearings as per manual but maybe should have been tighter...ideas? they work fine when applying the brakes, but on normal smooth road i see the pogo ing...
- RIP: cookie
Re: forks
The atf is not the problem, most use it and honda recommended it.
- jdvorchak
Re: forks
I think what he's describing is worn out bushings inside the fork lowers.
Did you take the forks apart?
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- 489 Views
Last post by Track T 2411
- 8 Replies
- 414 Views
Last post by pidjones
- 10 Replies
- 882 Views
Last post by 82aspy
