Great tutorial!
Starting woes
Re: Starting woes
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- mcgovern61
Re: Starting woes
If you are getting 14.8 at idle, just increase the RPM's to 3K and see if it creeps past 15vdc. If so, then yes you are overcharging. I have found on two of my 1100's that the overcharging was caused by the RR plug being dirty at the connections and not getting a good read on the sense wire. Pulled the plug, clean connections on both sides and back in. Solved it on both bikes. Average charge voltage running 14.6 at the highest and actually drops a bit at higher RPM but never below 13.2vdc.
Gerry
Current ride: 82' GL1100
1st ride: 81' Suzuki GN400
- kerryb
Re: Starting woes
I chased starting/battery issues for awhile...Rebuilt starter, charging battery, etc. My problem was finally solved when someone said "make sure you clean the contact point between the starter case and the engine case" problem solved! Just one more detail in the mix!
All part of the adventure...
- BlueThunder
Re: Starting woes
I solved my charging issues by grounding the rectifier directly to the negative battery post.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
Re: Starting woes
Finally got a chance to dig into this. Here are my results.
Battery, cold: 12.4v
Charging, @ idle: 14.85-14.91v (minimal change from 1k to 4k RPM).
Jump wire from black wire at regulator to pos. battery terminal -
Charging, @ idle: 14.49-14.56v (minimal change at higher RPM).
Battery 12.8v key off
Opinions?
Opinions?
- 14 Replies
- 835 Views
Last post by heath1066
- 8 Replies
- 409 Views
Last post by Don R
- 20 Replies
- 770 Views
Last post by tlbranth
- 1 Replies
- 309 Views
Last post by Whiskerfish
- 6 Replies
- 270 Views
Last post by heraldhamster
