Oldboy's 82' Resto Rod... Final
- Dragon Rider
- Lead Member
- Oldboy
Side Cover Badges...
Well thoses badges are from...get this a GL100...yes a 100. I was ebaying one day and made a typo. I found these badges. It turns out in Thailand honda sold GL100 with the super deluxe name tag. The funny thing is they were actually 125 cc's.
Hers more assembly pics.
[/list]
[/list]
Cheers...
Just Wing-it
Just Wing-it
- Sagebrush
Who won the race? Man, when you get them that clean you almost hate to ride them and watch everything slowly deteriorate. But I think I'll keep riding mine .
- Oldboy
Video proof
I have video proof it ran 13.16 @ 99.xx mph. There might of been a bit more in it, but the track was covered in anti-freeze twice and clean up time dragged on too long. The Clutch was slipping pretty good during the last run (slowed to 13.26) and we were crossing the finish line just getting into 4th. I heard there was a 4:10 ratio final drive for a GL1000... stock is a 3:40. Can anybody verify this?
Cheers...
Just Wing-it
Just Wing-it
- Cookie
- RIP: 1950-2011
- Hoosier Daddy
I tell you what, That carb rack before and after is very impressive all on its own! I bet theres not much better than building a bike that nice then takin her out and floggin on her at the strip...
SAAAA-WEEEEEET!
SAAAA-WEEEEEET!
- Oldboy
Goldwing parts...
I just thought I'd mention, there a guy in the Toronto Ontario area, his name is Larry Scott. He has parted out well over 100 wings and has parts
and parts and parts. This project would not have been possible with out him. Thanks Larry. If you need Goldwing stuff heres his email.
scott@netrover.com
scott@netrover.com
Cheers...
Just Wing-it
Just Wing-it
- Hoosier Daddy
You sir, are an inspiration!
Serious
Please keep up the Before and Afters!
Serious
- OhioBill
- My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
Your bike rocks. What spokes did you use for the front wheel. Did you use stock and cut them down or did you special order them? What was their length?
OhioBill
Retired and Loving it.
1979 Black (to be restored)
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
- Oldboy
Wheels
The front & rear rim are the same size 16" X 3". They are both Harley
Davidson. I originally bought 2 knock offs from ebay, but once I finished lacing the up and started to tru them, I realized that there was no way to make them straight. Thats when I bit the bullet and bought the Harley rims locally. The spokes are from Buchanan Spoke & Rim. They will make any spoke you need all you have to do is tell them rim & hub. 3 weeks later they're at your door. It was easy & simple.
The rotors are GL1000, you have to use these because they are 6 bolt as compared to the GL1100 being 5 bolt. I had to play with spacers in order to get the wheel centred. Also you have to rework the caliper mounts, because the cl to cl of the rotor centers is about .125 wider.
The fender is off a CB900 (noy sure of the year). I turn it around relocated the speedo cable guide and replated it. I didn't realize at the time that the fork mounts must be higher up on the 900 and therefore had to make an adapter to locate the fender at the right height. 2 pieces of stainless and stainless hardware.
The carbs....before
& After.
Well heres where I may get some flack.. I first clean my carbs on the outside with the finest grade glassbead we have at our shop. Of course I tape off all the opening and am extremely carefull. Then I dissmantle them and clean them extensively in solvent. This way I get a uniform finish on all the carbs. I polish the slider lids and bits and pieces get gold zinc plated even though they weren't originally. I put rebuild kits in all of them, and the only problem there was the pilot or low speed jet was pressed in these carbs (obviously 80 or 81 carbs) and they can be a real s.o.b. to get out. It took a while. I should have checked this before I started and gotten carbs off an 82 or 83. All & all they worked out well and perform great!
Theres a couple of pics up above . Glassbeading carbs is not recomended by me. But these carbs were a mess so I had nothing to loose. Its not my first time.
The carbs....before
& After.
Cheers...
Just Wing-it
Just Wing-it
- 18 Replies
- 942 Views
Last post by rnelson
- 12 Replies
- 877 Views
Last post by Track T 2411
- 27 Replies
- 2784 Views
Last post by 82aspy
- 49 Replies
- 4530 Views
Last post by pass_the_bacon
- 33 Replies
- 4520 Views
Last post by Irishman1
