32/36 weber conversion
- jake2012
Well needed something to get me riding while I await parts for the original carbs; so I whiped up this configuration for cheap. Had a VW carb kicking around with Type #3 manifold so I bought Dayco 81111 radhose that comes with a stainless spring inside. I cut 3 down to 5 3/4" and #1 at 6". Used #24 x 5/16 wide stainless clamps on elbows and 1 3/4 - 2 1/4 x 1/2" wide on the manifold. Made a simple thottle cable bracket and drilled and taped a boss blank on carb to hold it. The only thing needed is a stiffening spring for the primary thottle shaft because the primary moves way to easy and causes a suprise burst with slight twist. A spring will cure that. I also cut of the fuel inlet / filter so it would fit between the frame rails. It fired right up and runs fantastic. I like the kick you get when you hit the secondary.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1977 custom hawg chopper
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- Placerville
Re: While I rebuild my carbs
My hat's off to you.
Others who have done similarly have had the rubber tubes sag under heat. Maybe the springs are enough?? Ingenuity.
- jake2012
They were my inspiration. In wanted to ride so I did a little homework and found a piece by a Dayco rubber engineer who said that "exposure to pump gas might cause some swelling"... due to them being made from EPDM and not Viton. I hope it works for awhile. The springs are the key for they stop it from constricting girthwise however before I hard mounted everything you could see the whole thing pull downward from the vacuum forces when I rev the engine.ericheath wrote:Others who have done similarly have had the rubber tubes sag under heat. Maybe the springs are enough?? Ingenuity.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
It's alive!!!!
- jake2012
Desided to reinforce just to make sure there's no sag plus it looks better. when done I'll get out the ole dremmel and trim them up.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
Ready to ride yee haw!
Took her for a spin and boy does she run nice! just a couple little odds and ends to button up and she'll be ready for some longer shakedowns. I pulled one of the radhoses off after a run and the inside was dry as a bone; that's a good news for longevity of the rubber. I thought I was going to have to play with the jetting other than a 170 air jet that I installed but she's fine; plugs are coming around from black. I might stick with this setup if the gas mileage is as good as I've read.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- gearhead4207
- My Album: http://s1366.photobucket.com/user/gearh ... %20Uploads
thats cool ,but iwonder if its like the vw in the winerter my carbs were always freezing on my old baja but looks real good.
83 gl 1100 i stripped gone but not forgotton!
82gl1100sold
black betty
81 gl1100sold
78 gl1000 bagger mongrel sold miss you my friend
87 aspencade sold
84 aspencade f4-b build :mrgreen:back
87aspy stripping for road warrior
82gl1100sold
81 gl1100sold
87 aspencade sold
- jake2012
We're not in Kansas anymore TOTO.
The winters aren't to bad here in SC plus I removed the shield so the radiator will be blowing right on the carb; but if needed I'm sure I'll rig something. Stay tuned
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- gearhead4207
i will .hey got a question in your pic i see an alternater could you tell me more about that .
82gl1100sold
black betty
81 gl1100sold
87 aspencade sold
82gl1100sold
81 gl1100sold
87 aspencade sold
- jake2012
check out shop talk
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
ELECTRA is finally done! Time to
I like the Weber 2bbl in that it is easy to work on and dial in and make mannifold runners. If your a HOTROD this setupis not for you but if you like to ride asllot and not work on carbs allot this rig is the best not to mension the gas mileage. I also love my $40 GM alternator. The 2 biggest problems / complaints on this site I have overcome for cheap
. If you don't have skills you'll need plenty of $$$$ for a Stator replacement and the same for the stock carbs and most likely you'll have reacurring problems; that drive many to hate WINGS.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- SloMo228
What kind of seat is that? It looks really good. The whole bike does, actually.
- jake2012
Thanks, It is from a 94 Seca I modified and recovered it. However to make it fit/ work you'll have to chop your gas tank.SloMo228 wrote:What kind of seat is that? It looks really good. The whole bike does, actually.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- 82aspy
also .....gotta find me that ALT shop tawk stuff
edit - http://www.ngwclub.com/forum/viewtopic.php?t=41463
ngw quotes
ngw quotes
