Fork Swap Info/Questions
- Lead Member
OK! I have aquired a set of forks from a 2002 zx6r. I have found the upper and lower bearings on allballs that they say will work. But, as they say on the website this is just the correct size of bearing's that will work, it does not necessarily mean that the for swap has been done nor does it mean it will work without modification. Does anyone have any info on this swap? Has anyone done it before or know if it's possible? Granted I could find out in a couple hours time out in the shop, I just don't want to order parts the I don't need unless I absolutely have to. Any info is greatly appreciated!
- The zx6r forks
- 20170123_170340.jpg (61.79 KiB) Viewed 278 times
- g.jpg (61.96 KiB) Viewed 278 times
- 20161101_131038.jpg (164.53 KiB) Viewed 278 times
Re: Fork Swap Info/Questions
Did something similar installing late CB1000 forks and triples on a 75. The big issue is length of steering shaft. The bearings will need to set properly on the shaft both top and bottom. Top is likely where you will encounter the problem. My machinist actually put the entire lower tree in the lathe and turned it to match the original. If your shaft is not long enough they may be able to press it out and use the original one (requires grinding off the weld on the bottom) I have had that done also.
Another factor of course is the overall length of the fork legs. On the 75, I just moved the fork legs up in the triple clamp and mounted clip-ons above the triple. If the legs are too short, several of the guys have machined extensions to adapt the top.
- Lead Member
Easter wrote:Did something similar installing late CB1000 forks and triples on a 75. The big issue is length of steering shaft. The bearings will need to set properly on the shaft both top and bottom. Top is likely where you will encounter the problem. My machinist actually put the entire lower tree in the lathe and turned it to match the original. If your shaft is not long enough they may be able to press it out and use the original one (requires grinding off the weld on the bottom) I have had that done also.
Thanks for the response! I have done some measuring already and the stem is shorter than stock. Im not concerned with fork length though. I'm losing less than 2 inches which is fine with me. I've already lowered the rear 2 inches (which I may change at some point). If I get this front end to work it will completely change the direction I'm going in anyway. Again, thanks!
- Rusty Probie
Greetings ,
looking for info on installing a springer/girder front end on '82
thanks
thanks
gnhbus wrote:Greetings ,
thanks
This would be better asked in it's own thread.
- 7 Replies
- 446 Views
Last post by hatchward
- 15 Replies
- 464 Views
Last post by cbrianroll
- 10 Replies
- 287 Views
- 13 Replies
- 834 Views
Last post by duke182
- 38 Replies
- 1468 Views
Last post by Sidecar Bob
