Always trying new things.. Motogadget M-Unit
wingrider
Re: Always trying new things.. Motogadget M-Unit
#61
Post by wingrider »
CYBORG wrote:Been, following this (sorta) And may have missed it, but what is the price? Some of the "farkles" have peeked my interest :lol:
Doug, they are running about $300...
#62
Not what I would call expensive considering what they do. I'm more old school when it comes to gauges,( and other things), but I might look into it for a future project
#63
#64
Jury still out on the Lithium Battery. By rights it should spin the starter, but I don't think the factory charge was very much. I've been step charging it, babysitting it, to see if it will be enough. Have to be careful charging these things.
#65
Once I got my Lithium right to where it was getting a good charge, it spins my 1200 over easily. At first, it didn't seem to last long. Spun it over rapidly but in cooler weather only three or four bursts and she played out. If my bowls were a little low and I didn't choke it right away and get gas to the cylinders quickly, sometimes it ran out of juice before it started. I put the charger on it, because running them too low is a no-no. They do recover quickly though. I originally had mine set up to read actual battery voltage via a relay like lots do due to corrosion and voltage losses. With it like that, I think the regulator was seeing 13.2 or more at the battery and dropped the charge rate. 13.2 for a lead acid is still a positive charge from 12.6 volts, but for a LIFEPO4 it is minimal. It ended up dying a few times on me while riding. So I ditched the relay and it has been great ever since. (Two summers now) Their Achilles is cold weather. They hold an amazing charge just sitting in the cold. Last winter I would randomly check it and it was 13.6-13.8 volts all the time. Turn the ignition on for three seconds and it would fall quickly. Leave it five minutes and it would recover and then have enough to turn the engine over. They are a different bird.
When I came in from a 1-2 hour ride, I would check it and sometimes it would be 14.6 to 14.8 which according to the manual is too high. Turn the key and headlight on three-five seconds and it would drop to 13.8. Leave it until the next day and it's 13.8 volts. I think 14.4 is the recommended maximum charge on them.
I think a volt meter might be a very good idea with them.
#66
sunnbobb wrote:Doug: https://revivalcycles.com/
Thanks. saw the guys video. Very interesting. Don't want to mess with what I got already, so I need to look for a project worthy of one
BikeMaine
#67
Post by BikeMaine »
ericheath wrote:Once I got my Lithium right to where it was getting a good charge, it spins my 1200 over easily. At first, it didn't seem to last long. Spun it over rapidly but in cooler weather only three or four bursts and she played out. If my bowls were a little low and I didn't choke it right away and get gas to the cylinders quickly, sometimes it ran out of juice before it started. I put the charger on it, because running them too low is a no-no. They do recover quickly though. I originally had mine set up to read actual battery voltage via a relay like lots do due to corrosion and voltage losses. With it like that, I think the regulator was seeing 13.2 or more at the battery and dropped the charge rate. 13.2 for a lead acid is still a positive charge from 12.6 volts, but for a LIFEPO4 it is minimal. It ended up dying a few times on me while riding. So I ditched the relay and it has been great ever since. (Two summers now) Their Achilles is cold weather. They hold an amazing charge just sitting in the cold. Last winter I would randomly check it and it was 13.6-13.8 volts all the time. Turn the ignition on for three seconds and it would fall quickly. Leave it five minutes and it would recover and then have enough to turn the engine over. They are a different bird.
This post certainly discourages any thoughts of a Lithium battery for my bikes.
Kevin
1982 GL1100A
#68
Not sure I would trust one not to catch fire. To many news reports on problems
BikeMaine
#69
Post by BikeMaine »
CYBORG wrote:Not sure I would trust one not to catch fire. To many news reports on problems
action1
Kevin
1982 GL1100A
#70
LIFEPO 4 batteries are not the same as Lithium Ion batteries which can both catch fire and explode. How many lead acid batteries have you seen explode?? I'll bet it's more than you've seen LIFEPO4 batteries.
They are also being retro- fit into bikes/cars with regulators designed for 6 cell, 2.1 volt per cell, lead acid batteries. I really thought by now they would have caught on more, but using a different regulator. Unfortunately that's another cost to an already expensive transition. Maybe some day we'll go back to adjustable regulators. LIFEPO4 batteries are 4 cells of 3.3 volts per cell. ( or eight cells or twelve or sixteen depending on application) Mine is an eight cell. They crank better because they're higher volts, 13.2 vs 12.6. So they need a bit more juice on the bottom of the charging scale, but are not supposed to be charged above 14.4 volts. Most warranties are pretty vague about coverage if they're overcharged. I think most automotive regulators run above 14.4 volts.
I had the misfortune on my first ride cooking the battery in just a few miles because my sense wire had gotten pulled off its connector. The battery was hot and oozed some tarry looking stuff out of it. I was pretty nervous for the reasons mentioned by Cyborg. ( Since have found out they don't run the risk of runaway cells ) Later in the summer I took the cooked apart and found all but one cell were still usable. Some were still 3.2 or 3.3 volts. They are just bigger 'D' cell A123 batteries in a case of plastic. The better ones have balancing charger capabilities. The black goo that oozed out of mine was melted plastic. After one summer of issues, I thought I would give up but I have been happy since.
If you call about a Goldwing, they'll tell you you need a sixteen cell battery. I tell them it's for a VFR1000. If you run a lot of accessories, maybe you need more. So I'll stop, back to the M-Unit.
#71
Good info, exactly what I did re: vfr 1000. Mine is a shorei.
Sugs
#72
Post by Sugs »
This is why I like Bikemaster Lithium batteries. They have a built in equalizer and over charge protection board. Not sure about other brands.
_______________________
'79 Honda GL1000 Goldwing
#73
Mine (Ballistic) has the equaliser but recommend putting it on a balance charger now and then. I don't have one. It has a small rubber boot at the top of the battery which removes to show the balance tabs. Each finger measures a 2- cell unit. One must be the ground. I can use my DVM and check the voltage of each group of two. They have remained quite close for me. If I start getting a significant difference between them, I'll probably get the charger. I got to see the inside when I tore it apart. It is simply small wires going to each group of parallel - in my case- group of two batteries. EHE has a good post building his own A123 LIFEPO4 battery.
#74
Post by HOTT »
sunnbobb wrote:.... Mine is a shorei.
Me too. Mine is still going. Six years now. Just wired it up :dunno: No gadgets no gizmos.
(never got anything close to that with lead acid)
I also have Scorpions for 2 yrs. now. The newer batteries
have been coming uncharged since the whole hover board mess, so
I was forced to get a 'Tender for Li's' for the initial charge. It has a charge status light.
All my batteries always show overcharged so the charger never gets used. I just let them be. again :dunno:
I never ask any of my batteries (Lith or Acid) to run a starter until
the carbs have enough fuel to fire. A little carb prime can save a lot of wear & tear, IMHO.
#75
What CCA are you guys running on your lithiums?
