King_Coopr's "Project" Log
Re: King_Coopr's "Project" Log
The 1200's never used a mechanical tach, so if you're desire is to use stock style gauges, you are going to need to do some work! There is a thread on modifying the electronic 1200 tach guts to fit into an 1100 style gauge pod. In fact, I think Cyborg may be familiar with that process.
As far as the wiring goes, unless you're a masochist or a wiring guru, rewiring the entire bike is a serious undertaking. Don't let it bog down the whole project. In my humble opinion, change or repair what you need to, and move on to more important stuff. I'm saying this from experience...
Well that's a bummer...I really don't like the looks of the gauge cluster and doesn't fit the look I want to go for.
Doesn't Mike-c have an 84 aspy with normal gauges and round headlight? I tried to look for a picture and couldn't find one that was still working
0 I have a 1200 tach in a 1000 housing. Works good. I did the conversion myself. Wasn't that hard
Got a picture of how it looks? I'm sure I'll see it in person sometime soon but wanna get an idea in my head lol
no pictures. But it looks like a stock 1000 tach. Take a minute. and come over for a look.....when you can
Like this one?
- GL1000_052.JPG (55.14 KiB) Viewed 222 times
You the can make it look anyway you want. I just installed the face plate I wanted on the electronic tach, and mounted it in the 1000 ho I think the tach came out of a Yamaha tach. I really don't remember, just something I had laying around
That is what a 'stock' gauge cluster would look like. If you go aftermarket, you will have a much wider variety to choose from...King_Coopr wrote:Like this one?
Got to work on it for a few mins today and played with the handlebars a little and kinda like them like this lol mini ape hangers
- 0927152242.jpg (63.41 KiB) Viewed 202 times
A couple of questions....
1. One of the air lines that goes from the forks to the fairing is broke. Is there a way to remove the lines and add a fitting to add air when needed and rid myself of the on board compressor?
2. In order to use the digital gauges (for now) do I have to remove the wiring inside the fairing so everything will connect?
3. My exhaust brackets were rusted out so now I have straight pipes while it sounds cool is way to loud and wondered about cheap alternatives. Ive read about using Harley exhausts, is it specific models? Smaller/more discrete the better as Im going for that cafe look.
Thanks and sorry for the questions but im a noob :/
Well after a little more searching I've found the answers to a few of my questions. The progressive springs will allow me to run without the air and I can use harley slipons and just so happens a guy I know has some stock ones and aftermarket one that may work.
Still debating wether I wanna remove the motor and clean it up a bit and repaint the frame or powdercoat but I'm trying to be as budget friendly as possible right now. Gotta get the gl1100 tank then I can start making the seat pan. Kinda at a holding pattern until I start spending money. Ugh
Just some advise from someone who's been there, done that. Fix what needs to be fixed, one thing at a time, until you can get it out on the road. Then you can go back and do the cosmetic stuff, modifications, etc, with confidence that everything works as it should, and will when you're done. This approach works on several levels. First, the bike remains rideable most of the time. Second, you get a feel for the bike and how much you like working on it. Third, you can budget your expenses better, as well as shop around for the bigger purchases later. Fourth, you will get a feel for just how much of a project a full-on refurb/custom is, and how much time you will be able to dedicate to it. I sat staring at a pile of parts, frames, wheels, and fairings (and moved the lot of them a couple of times ) for a couple of years due to either money, time, and/or motivation issues, when I probably could have been riding. My 2 cents.King_Coopr wrote:Still debating wether I wanna remove the motor and clean it up a bit and repaint the frame or powdercoat but I'm trying to be as budget friendly as possible right now. Gotta get the gl1100 tank then I can start making the seat pan. Kinda at a holding pattern until I start spending money. Ugh
Good wrenchin'
Todd
Thanks well put...
Small update:
The project has a name! I asked my kids to name her and only daughter came up with one - Miss Alice. So I'll call her Alice!
Also snagged a Harley exhaust off of a guy I work with for $20. I still need to make a bracket to mount it but I "mocked" how it should look just to see what I thought. What do you guys think? At first I thought it was way too big.
Small update:
- 1015151146~2.jpg (65.5 KiB) Viewed 139 times
- 13 Replies
- 1115 Views
Last post by rcmatt007
