Diamond in the Rough: My 75 Goldwing
Re: Diamond in the Rough: My 75 Goldwing
Heat and a freezer are always good for installing bearings and races also.
- BigBrian27
Exactly what I was looking for!Patriccio wrote:Ok Ok Ok Ok Ok, I have two windows open on my laptop, a Toshiba Satellite, 6 years old, but it's still working well.
Dude! I'm a mess. Those pics are of the innards of my brake calipers; you, sir, are right. I apologize for wasting your time. Pics of the bearing assembly are posts #32 & beyond. And as I recall, I had trouble seating the lower bearings. Now I recall (a little bit better). I had to cut off the lower races in order for the new bearing assembly to fit properly. Other members jumped to my aid when I wasn't sure what to remove. I slipped a larger diameter pipe over the stem & seated the bearing w/ a hammer, the beeeeest tool.
I knew I wasn't crazy! Well maybe...
1975 Honda GL1000 Goldwing
1992 Kawasaki Concours ZG1000
Solid rotors suck! I have the PDF for the rotor drilling template, PM me if you would like a copy.
- BigBrian27
Definitely a trick that has helped me out in the past! Will be sure to employ it when installing these bearings, thanks.robin1731 wrote:Heat and a freezer are always good for installing bearings and races also.
- BigBrian27
Ok! Started my GL1200 clutch conversion today. Got the old parts out, change your oil kids! Put the new parts in! Am I correct is saying the GL1200 clutch has no springs???
This is as far as I got. Yes I swapped in the 1200 oil pump gear. I guess I'm confused how the 1200 clutch works without any springs. Also I did not change any clutch plates does anyone know if thats necessary?
- 1231161428.jpg (114.12 KiB) Viewed 183 times
- 1231161505.jpg (98.62 KiB) Viewed 183 times
- 1231161603.jpg (110.07 KiB) Viewed 183 times
- 1231161603a.jpg (96.83 KiB) Viewed 183 times
The 1200 clutch has one spring....one BIG spring. Old Fogey did a write up on it just in case you missed it. It is located in this post.
Hope that helps a little.
- BigBrian27
Thanks for that link, still unsure of the one big spring you speak of but i'm sure my clutch is installed correctly.wingrider wrote:The 1200 clutch has one spring....one BIG spring. Old Fogey did a write up on it just in case you missed it. It is located in this post.
However, I did come across this
NO idea why anyone would need to modify the GL1200 clutch plates when putting it in the GL1000.All the plate thickness measured up OK but I had to use the hated 'B' plate as I didn't have spare plain ones.
Hopefully someone smarter can come along and clear that up...
- BigBrian27
It's a diaphragm spring, i'm an idiot!
The b-plate is for early models, not the 1200. You're making good progress.
- BigBrian27
Good to know, thank you for the motivation, it is much appreciated.ericheath wrote:The b-plate is for early models, not the 1200. You're making good progress.
- BigBrian27
Searching Craigslist this morning I found a 1982 GL1100 for sale as parts only. Thinking about offering him $150 and recouping some of my money while keeping the parts I want.
Can I just hook up a battery to the starter to check compression?
http://allentown.craigslist.org/mcy/5938200672.html
You should be able to just hook up a good battery for a compression test, as long as you can get decent connections. WOT, and several revolutions per cylinder... If it's been sitting for quite some time, I wouldn't crank it much as there's likely very little oil protecting the rings and cylinder walls.
- BigBrian27
Maybe Ill shoot some fogging oil in the cylinders first to lube them up.Track T 2411 wrote:You should be able to just hook up a good battery for a compression test, as long as you can get decent connections. WOT, and several revolutions per cylinder... If it's been sitting for quite some time, I wouldn't crank it much as there's likely very little oil protecting the rings and cylinder walls.
- BigBrian27
Assuming the 1100 engine is in good shape (compression, etc.) I was toying with the idea of swapping that into my 1975 GL1000. I would use the heads and cams and carbs off my 75 so I would have the most power out of the combo of the 2, also that should allow me to keep things relatively simple considering the ignition and frame clearance.
I have a few questions;
1. Am I a fool for even thinking this will work? From what I have read this should not be a problem, but I'd like some opinions from someone who has more experience than me.
2. I just put a GL1200 clutch in my GL1000, I am assuming I can just transplant parts into the GL1100.
3. Which head gasket would you use? I believe you are supposed to match headgasket to head not to block, correct?
4. I would use the GL1000 carbs then I assume? Since they are from a 75 they should push a little more fuel which should make things smoother.
Thank you all for the advice, and I appreciate the answers to my 1,000,000 questions.
-Brian
-Brian
- BigBrian27
On my way to look at this 1100 donor now.
- Screenshot_2017-01-02-07-24-18.png (557.25 KiB) Viewed 116 times
- BigBrian27
Bought the wing! $50 and it was mine. Got it home, started stripping it to remove the engine and found a cracked block....
Oh well.
Time to start selling off the parts.
Oh well.
- 14 Replies
- 555 Views
Last post by rcmatt007
- 1 Replies
- 202 Views
Last post by Track T 2411
- 9 Replies
- 554 Views
Last post by WalterM817@aol.com
- 27 Replies
- 1459 Views
Last post by lcallison
