Diamond in the Rough: My 75 Goldwing
- BigBrian27
Re: Diamond in the Rough: My 75 Goldwing
Here she is when I brought her home.
- 0102171025.jpg (157.04 KiB) Viewed 267 times
1975 Honda GL1000 Goldwing
1992 Kawasaki Concours ZG1000
Solid rotors suck! I have the PDF for the rotor drilling template, PM me if you would like a copy.
Hoping for a better outcome, how bad is the "crack?" Others here have feared cracks that were casting marks. Just checking.
- BigBrian27
Part of the case was broken and pushed out sevral mm. It was BAD.ericheath wrote:Hoping for a better outcome, how bad is the "crack?" Others here have feared cracks that were casting marks. Just checking.
- BigBrian27
Some goodies came in the mail today!
VFR masters, 84' GL1200 clutch cover and cable luber!
I'm getting excited!
- 0103171848.jpg (148.21 KiB) Viewed 240 times
- BigBrian27
This happened when I was removing my front wheel bearings. How screwed am I?
- 0104171855.jpg (102.23 KiB) Viewed 220 times
I have a complete 78 front end if you are interested.
Future owner of a oldewing.#12 in my goldwing history.
- BigBrian27
I wont be able to run my Lester wheels with the 78 front.doubleminded wrote:I have a complete 78 front end if you are interested.
Thanks anyway.
- BigBrian27
I keep catching myself looking at the dual Weber IDF40 carb conversion...
It's really intimidating to undertake a modification of such measure.
- BigBrian27
Getting ready for when the frame comes back. Do I have to remove this collar and rubber seal to do the All Balls steering bearings?
- 0108170915.jpg (110.99 KiB) Viewed 159 times
- 0108170915a.jpg (140.01 KiB) Viewed 159 times
Yep
- BigBrian27
I was afraid of using heat on the metal retainer for fear it would damage the seal but turns out I can ditch the seal so I'll heat away!wingrider wrote:Yep
Thanks!
- Patriccio
I cut the lower race w/ a Dremel tool w/ small metal cutting wheel. Slow 'n easy. If you're good, you could use a grinder /w 4" blade. Slow 'n easy.
- BigBrian27
I will try the dremel method tomorrow, thanks!Patriccio wrote:I cut the lower race w/ a Dremel tool w/ small metal cutting wheel. Slow 'n easy. If you're good, you could use a grinder /w 4" blade. Slow 'n easy.
- BigBrian27
Time to start thinking about tires.
The bike currently has old, dryrotted tires on it.
The front is a 100/90-19 57H
The rear is a 120/90-18 71H
I'd like to run a 110/90-19 62V Shinko 230 up front and a 130/90-18 69V Shinko 230 in the rear.
I am assuming these should fit with no issues.
Anyone else running these sizes?
- 14 Replies
- 555 Views
Last post by rcmatt007
- 1 Replies
- 202 Views
Last post by Track T 2411
- 9 Replies
- 554 Views
Last post by WalterM817@aol.com
- 27 Replies
- 1459 Views
Last post by lcallison
