Diamond in the Rough: My 75 Goldwing
- BigBrian27
Re: Diamond in the Rough: My 75 Goldwing
I've been looking around for a better set of brake calipers for the front of these bikes.
Looks like I may have found a solution.
The Brembo P32 and P34 apparently have the same (or VERY similar) center to center distance for the bracket mounting holes.
I have emailed a company who sells them to get some more specific measurements.
If it fits I will purchase and post back with results.
Has anyone ever tried this?
-Brian
-Brian
- brembo brake.jpg (35.1 KiB) Viewed 232 times
1975 Honda GL1000 Goldwing
1992 Kawasaki Concours ZG1000
Solid rotors suck! I have the PDF for the rotor drilling template, PM me if you would like a copy.
- Sugs
Would be a great option if they fit, wonder what master cylinder size is needed.
_______________________
'79 Honda GL1000 Goldwing
- BigBrian27
Should be very similar to the VFR setup so those of us who have VFR master cylinders should be good to go.Sugs wrote:Would be a great option if they fit, wonder what master cylinder size is needed.
- BigBrian27
The Brembo's are close but not close enough. A bracket would have to be fabbed.
- BigBrian27
Work continues while I wait for the powdercoater to finish my frame and other parts.
Got the engine all sealed and the clutch hydraulics installed.
Blasted all the brakes and brackets so they are ready for paint.
Lastly, got a set of louvers in the mail. They accidentally sent me a row of 4 when I ordered a row of 7. No big deal the new set is in the mail.
I am planning on welding the louvers to the top of the shelter after cutting out the metal underneath. This should give some ventilation and a unique, one-off look to my bike.
My only question is, should I have the scoops face the front of the bike or towards the rear?
- Clean brakes
- 0112171956.jpg (77.89 KiB) Viewed 214 times
- 0112171955a.jpg (65.9 KiB) Viewed 214 times
- 0112171955.jpg (60.36 KiB) Viewed 214 times
- 0112171955b.jpg (65.09 KiB) Viewed 214 times
- BigBrian27
Got ahold of my powdercoater since they've had my frame for almost 3 weeks. They said it should be done by the weekend.
my vote is to face them towards the read..you will get the ventilation you want without the road crap...
- BigBrian27
Yeah that is what I was thinking as well.5speed wrote:my vote is to face them towards the read..you will get the ventilation you want without the road crap...
- BigBrian27
Frame is finally done at the powdercoaters but I will not be able to pick it up until this coming weekend.
I did however stumble upon a great deal and picked up this 1992 Kawasaki Concours!
It needs little things like tires, master cyl rebuild, tune up, etc but I cannot wait to ride!
- 0121171320.jpg (143.32 KiB) Viewed 175 times
- 0121171320a.jpg (116.06 KiB) Viewed 175 times
- 0121171321.jpg (132.87 KiB) Viewed 175 times
- BigBrian27
Got my progressive front springs in! So i disassembled the forks and found these 2 small springs, one in each fork.
They are not on my parts fiche. Are they aftermarket???
Do I put them in with the progressive springs?
- 0125171903_HDR.jpg (98.62 KiB) Viewed 156 times
Nope. Add later if you need them. Being naked, you shouldn't.
- BigBrian27
Perfect thanks!ericheath wrote:Nope. Add later if you need them. Being naked, you shouldn't.
- flyin900
Usually the progressive springs indicate if you need to use a spacer in the forks as some of their springs are used in a variety of bike applications and don't always fit a specific bike exactly out of the box.
The instructions will tell you if you need to fabricate a spacer for the GL application. Those springs as noted on your other post asking about them are not correct for the GL1000.
Current Bikes:
- BigBrian27
Re-read the instructions, no spacer needed for the GL1000.flyin900 wrote:Usually the progressive springs indicate if you need to use a spacer in the forks as some of their springs are used in a variety of bike applications and don't always fit a specific bike exactly out of the box.
- BigBrian27
I am picking up the frame from powdercoating tomorrow! Yay!
Tonight I went into the garage and hooked up my master cylinder to make sure the GL1200 with hydraulic clutch conversion was working. After bleeding the heck out of it, it worked!
Ready to install the engine now!
- 14 Replies
- 556 Views
Last post by rcmatt007
- 1 Replies
- 208 Views
Last post by Track T 2411
- 9 Replies
- 555 Views
Last post by WalterM817@aol.com
- 27 Replies
- 1471 Views
Last post by lcallison
