The next 1975 restoration
- Irishman1
My 6th 1975 gl restoration is another blue green we picked up across the state in Spokane Washington. My first running resto and I planned on riding it home but the front brakes were locked up and so we came home without her and waiting until the previous owner could drop it off when they came over to our side of the state and delivered it to our island.
I started by removing the foot boards and heel-toe shifter and king/queen seat. This time Ive sent the carbs to pistol Pete to rebuild instead of doing it myself( im going to send all my other gl carbs to him as well, even the ones I've rebuilt).
Now to start stripping her down and building her up
- IMG_0295.JPG (280.83 KiB) Viewed 748 times
- IMG_0475.JPG (263.06 KiB) Viewed 748 times
In the garage:
1975 Honda gl1000 sulfur yellow( my first!) NGW BOTM February 2020
1975 Honda gl1000 red (Ruth's free bike) NGW BOTM January 2017
1975 honda gl1000 red. Eariest of my 75's 2/75 date
1975 Honda gl1000 blue green 5/75
1975 Honda gl1000 blue green 3/75
1975 Honda gl1000 blue green 4/75
1976 Honda gl1000 sulfur yellow
1977 honda gl1000 red black, Ian's next bike
1976 Honda gl1000 red next restoration
1975 Honda cb750 rebuilding soon!
1975 Honda gl1000 2/75 blue/green
1978 Honda cb750f super sport
1979 Honda cb750f super sport
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
"I really need a BIGGER garage!!"
"I got a bigger garage!!!!
" ride'm, don't hide'm!!!
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- Irishman1
Re: The next 1975 restoration
More pics of progress so far. The sulfur yellow in background is next!
- IMG_0498.JPG (271.23 KiB) Viewed 746 times
- IMG_0499.JPG (279.01 KiB) Viewed 746 times
- IMG_0750.JPG (221.99 KiB) Viewed 746 times
- IMG_0753.JPG (258.06 KiB) Viewed 746 times
- IMG_0756.JPG (252.98 KiB) Viewed 746 times
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- Irishman1
Some oem parts started to arrive. Original oem braided fuel line with double wire clamps. Oem fuel filter. Oem screws, nuts and bolts.
- IMG_4492.JPG (241.81 KiB) Viewed 709 times
- IMG_4493.JPG (297.46 KiB) Viewed 709 times
- IMG_4495.JPG (177.01 KiB) Viewed 709 times
- IMG_4496.JPG (257.35 KiB) Viewed 709 times
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- Irishman1
Started work on the electrical restoration last night. Removed and repaired old dyna lll kit and wiring and repaired old splices. Cleaned and painted shelter frame and reinstalled stock electronics. Will go back to stock points and condenser.
- P.O.'s Old wiring and missing reserve headlight unit.
- IMG_4633.JPG (193.55 KiB) Viewed 683 times
- Old dyna 3 heading for the garbage
- IMG_4634.JPG (240.77 KiB) Viewed 683 times
- Ignition wiring will be brought back to stock
- IMG_4635.JPG (164.56 KiB) Viewed 683 times
- Shelter frame paint and reinstalled, starting to re install stock wiring
- IMG_4638.JPG (187.33 KiB) Viewed 683 times
- Old wire where a splice had been. Will cut and install oem spade
- IMG_4642.JPG (150.08 KiB) Viewed 683 times
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- Irishman1
Stock electronics back under the left shelter the way it should be! Next the battery and starter solenoid wiring back to stock. New RLU installed and of course, all new OEM honda bolts, washers, spacers and fasteners.
- Before
- IMG_4634.JPG (240.77 KiB) Viewed 682 times
- After, with harness repaired with oem wiring kit and a new RLU installed!
- IMG_4643.JPG (194.76 KiB) Viewed 682 times
- Before: RLU missing and jumper wires with a naked soldered splice between the two lower plugs???
- IMG_4632.JPG (180.56 KiB) Viewed 682 times
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- Irishman1
Got a little more done on the resto last nite. Trying to get as much done before my next surgery on the 8th of march. Cleaning the engine for paint and cleaned and painted the headers. Found the fuel leak on the #4 carb. It was the new gasket. Starting to rip out the dyna and wiring at the battery. Will re-wire the starter solenoid back to stock. Primed and painted the period correct marzocchi strada shocks too.
- Leaking gasket on #4 carb
- IMG_4684.JPG (189.36 KiB) Viewed 645 times
- Cleaning engine for repainting. Everything on the bike is in great shape
- IMG_4718.JPG (156.53 KiB) Viewed 645 times
- Wiring from the removed dyna 3 going to get replaced with oem points
- IMG_4719.JPG (153.84 KiB) Viewed 645 times
- P.o.'s relay wiring to be replaced with oem wiring
- IMG_4720.JPG (151.81 KiB) Viewed 645 times
- Front brakes to be rebuilt and painted
- IMG_4721.JPG (171.9 KiB) Viewed 645 times
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- Irishman1
Here's the marzocchi stradas after painting
- Marzocchi guts and polished carb runners
- IMG_4723.JPG (277.18 KiB) Viewed 645 times
- Painted stradas
- IMG_4724.JPG (175.05 KiB) Viewed 645 times
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- RIP: cookie
Lotsa nice work
- Irishman1
Got some more OEM parts for the blue 75 in the mail Saturday. Shelter hinge pins, washers and clips. A couple more sets of side panel screw pins, springs and pins for the OEM NOS 75 blue side panel and a set for the NOS 76 sulfur side panel, the next resto. I also got the shelter sides clear coated ( took longer because of the cold weather).
- Cleared side panel with max spray clear with hardener. I don't think I'll need to wet sand or buff
- IMG_4766.JPG (146.7 KiB) Viewed 599 times
- Side panel scre pin, spring and washer
- IMG_4768.JPG (172.66 KiB) Viewed 599 times
- Shelter hinge pins, washers, clips and honda emblem quick screws
- IMG_4760.JPG (155.42 KiB) Viewed 599 times
- OEM NOS blue and sulfur side panels will finally get to go home to a bike
- IMG_4763.JPG (222.46 KiB) Viewed 599 times
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- Irishman1
A little bit of a break to heal. Hoped to get more done before my surgery.
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
Heal up a bit first. Avoid infection at all costs. Then: You need a bike lift or chain hoist. I have both. The hoist is nice, but with my 7 foot garage ceiling it's tough to hook up and get the chain where it doesn't hit the bike. If you've seen Pedrotq's builds, he has lifting slings and tosses the bike up and down with ease. I have a plywood platform 24"by 30" that I slip under mine. You can sit on a chair and get to most things.
- Graham Cracker
Take care of that knee first...
Mark
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
- Irishman1
Back to work after recovery! Got the carbs rebuilt, leak tested, taken apart and put back together, leak tested, checked float height. Leak tested. Taken apart and finally replaced the carb to plenum seals! I thought I had used a new set of Randakk's seals but I re used old ones in a new bag!!! Finally got it!
- IMG_5728.JPG (278.1 KiB) Viewed 525 times
- IMG_5773.JPG (308.13 KiB) Viewed 525 times
- IMG_5872.JPG (263.53 KiB) Viewed 525 times
- IMG_5953.JPG (192.04 KiB) Viewed 525 times
- IMG_5954.JPG (314.67 KiB) Viewed 525 times
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- Irishman1
installed OEM braided fuel lines, clamps. Re installed repainted gas tank. Side panels. Rebuilt and painted brake calipers and master cylinder.
- Factory OEM braided fuel lines and clamps
- IMG_5968.JPG (169.05 KiB) Viewed 525 times
- Fuel pump installed
- IMG_6014.JPG (155.34 KiB) Viewed 525 times
- Repainted fuel tank back in
- IMG_6168.JPG (152.47 KiB) Viewed 525 times
- Side panels have new hardware installed
- IMG_6169.JPG (163.29 KiB) Viewed 525 times
- Front brake calipers about to be rebuilt and repainted
- IMG_6176.JPG (168.15 KiB) Viewed 525 times
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- Irishman1
Rebuilt and repainted front and rear brake calipers and masters. Applied red dots as per oem. Cleaned and polished front wheel and spokes
- Rebuilt and painted front master
- IMG_6174.JPG (92.84 KiB) Viewed 525 times
- Polishing front spokes and wheel
- IMG_6178.JPG (141.5 KiB) Viewed 525 times
- Installed rebuilt front calipers ready to bleed!
- IMG_6335.JPG (201.87 KiB) Viewed 525 times
- Getting close to come off the rack!!
- 11AFCED2-73A3-4AE9-A4C4-1C21159DEEF6.jpg (167.94 KiB) Viewed 525 times
- New OEM front side reflector spacer
- IMG_6337.JPG (190.53 KiB) Viewed 525 times
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- 10 Replies
- 1540 Views
Last post by JohnnyNumbers
- 25 Replies
- 2192 Views
Last post by Don R
- 8 Replies
- 1277 Views
Last post by KSmith
- 9 Replies
- 828 Views
Last post by TorontoGL
- 91 Replies
- 7963 Views
