VMAX Downdraft Carb conversion
Re: VMAX Downdraft Carb conversion
Both look really cool. Thanks for the info, pics and detail.
- BLIGHT
Here's a couple of pics of the downdrafts with the velocity stacks... wasn't running all that well with 'em but she looked cool with the stacks!!
Photos taken at my garage at the end of Laguna Seca MotoGP weekend in July this year 2013:
Some larger mains would likely handle the extra air comin' in!!! Mebbe someday....
BLIGHT
BLIGHT
'76 GL1000
Good work!
- Scottinaz
Cool looking setup. How does it perform compared to stock? Looks a lot like the webers in so many ways. Is there a possibility of some closeups of the linkage mods you had to do. I can see one extender for either choke or throttle, but other than that, not much. Also can you elaborate on the mounting, is it a stock venture or vmax part that you used that fits so well. Also, you mentioned tuning differences between vmx and venture, which set did you start with?
'76 GL1000
- BLIGHT
I don't know how it compares to stock, because I could not get it to run after I rebuilt the OEM carbs. It does run pretty fast though... surprisingly so!Scottinaz wrote:Cool looking setup. How does it perform compared to stock? Looks a lot like the webers in so many ways. Is there a possibility of some closeups of the linkage mods you had to do. I can see one extender for either choke or throttle, but other than that, not much. Also can you elaborate on the mounting, is it a stock venture or vmax part that you used that fits so well. Also, you mentioned tuning differences between vmx and venture, which set did you start with?
Rideability, easy starts, and rock steady idle are definite bonuses. I had hoped for better than 30-35 mpg but, I guess I need to stop grabbing the throttle so much. I purchased Venture carbs, but I fit the nicer looking V-Max smooth diaphragm covers. Working, complete V-Max carb racks go for about $400 USD on ebay pretty regularly. I'd still buy the rebuild kits anyway. The Venture jets are tiny and the GL did not run well on the stock jets. Might be more 'turnkey' with V-Max carbs and less jetting & needle adjustment.
I don't have any detailed pics of the linkage, bracing, and so forth, as I never intended to publish a 'how-to' guide. I'll remove an air-cleaner tomorrow and take a couple of close-up shots for you. Basically you need to widen the spacing between the carbs where they mount to the engine to around 5" center to center. That means a longer choke rod and an extension 'finger' between the throttle butterfly actuators. Also an adjustable cross tie-rod to synchronize the carb pairs. It's not the best setup, but it works, and I'm just so tired of working on carbs... so it stays for now. You'll see how I did it in the photos.
The carb 'boots' are stock Mikuni rubber flanged adapters. The GL intake ports have the bolts offset a couple of mm, but when you position the Mikuni flanged adapters over the ports, there is enough 'slop' in the screw holes to move the adapter over to line up perfectly with the engine port... then tighten the bolts. Simple ss clamps secure the carbs in the flanged adapters.
So.. if you decide to do it, I can offer a few pointers but you'll need to do the lion's share of the work and figuring things out on your own, OK?
BLIGHT
'76 GL1000
- Scottinaz
BLIGHT wrote:I don't know how it compares to stock, because I could not get it to run after I rebuilt the OEM carbs. It does run pretty fast though... surprisingly so!Scottinaz wrote:Cool looking setup. How does it perform compared to stock? Looks a lot like the webers in so many ways. Is there a possibility of some closeups of the linkage mods you had to do. I can see one extender for either choke or throttle, but other than that, not much. Also can you elaborate on the mounting, is it a stock venture or vmax part that you used that fits so well. Also, you mentioned tuning differences between vmx and venture, which set did you start with?
BLIGHT
Sounds good, I would enjoy seeing up close and personal how you did the linkages. Not trying to be daft, but the mikuni adapters you used were stock for the venture? I see plenty of them on Ebay that "say" they will work, but would prefer that it be confirmed by someone who did it before. I have done the Weber conversion successfully, but had to sell the setup due to financial concerns. This appears to be another workable setup that would work out cheaper than the Webers, and if the right carbs are sourced, cheaper than stockers.
'76 GL1000
- BLIGHT
Scottinaz wrote:BLIGHT wrote:I don't know how it compares to stock, because I could not get it to run after I rebuilt the OEM carbs. It does run pretty fast though... surprisingly so!Scottinaz wrote:Cool looking setup. How does it perform compared to stock? Looks a lot like the webers in so many ways. Is there a possibility of some closeups of the linkage mods you had to do. I can see one extender for either choke or throttle, but other than that, not much. Also can you elaborate on the mounting, is it a stock venture or vmax part that you used that fits so well. Also, you mentioned tuning differences between vmx and venture, which set did you start with?
BLIGHT
OK... here are some close-up pics:
This one shows a mount tab to hold the carbs square and on the right spacing. Made from 1/8" steel strap and drilled. Also shows the flex-coupler for the choke shaft. I got it to where I can pull the OEM GL choke knob and it lifts all 4 enricheners on the Mikunis... easy starts.
This one shows the clear vent tubes going up under the shelter for still air space (important) Also shows the enrichener shaft and linkage.
Pretty clear shot of the Mikuni rubber flanged adapter (carb boot) Vmax or Venture ones won't work! Also shows the vent tubes.
This one's kinda ugly, but shows what's under the tank tray... electric fuel pump (2 psi MAX!) and some of the throttle cross bar (linkage)
Over on the rider's left there are the two cable connections, one throttle (pull only) and the choke/enrichener cable (OEM GL1000) tight fit with the oval air filter, and an bit easier with pod filters
This shows the carb pair cross brace (aluminum channel) bolted to the carb spacer plate. Another stiffener under the carbs by the spark plugs holds everything 'square' in the other plane. BTW, you will need the shorty NGK spark plug caps... OEM's are way too long and cause interference.
Here's how I did the connection-extension of the throttle actuator and snyc-screws. Needs to be done on both pairs to widen carb spacing out to ~5" O.C., the little offset tabs are ~1" long, I made it out of steel strip so there is no flex. A lot of tedious cutting, grinding, bending, drilling and screwing it into place. PITA!!! If you get it right after a lot of trial and mostly error, it's pretty easy to sync carbs first as a pair on the left side, then do the right side, then adjust the crossbar linkage to sync the pairs. Sounds hard, but it isn't really if you know much about engines and individual carbs.
Another shot from a different angle showing the synchronizer tab 'extensions' and how they relate to the spring-loaded screws that come on these carb racks. Also shows the short spark plug caps needed for this conversion. Easily found on ebay.
Well... that's it! You're on your own now if you decide to do this... I kinda liked being the only GL1000 on the planet with VMAX/Venture downdraft carbs, so... if you decide to take the plunge and do it to your bike, please don't tell me about it! Good Luck!!
BLIGHT
'76 GL1000
- Scottinaz
Very cool and very informative. thanks again. I guess I shouldn't mention that I was able to pick a set of the Venture 1200 carbs up for $35 bucks then......
'76 GL1000
- BLIGHT
Don't mention it....Scottinaz wrote:Very cool and very informative. thanks again. I guess I shouldn't mention that I was able to pick a set of the Venture 1200 carbs up for $35 bucks then......
'76 GL1000
- Zinc Member
What an awesome machine you have put together , probably my favorite chopped up GL on this forum . Nice thinking out of the box on the downdraft set up , hope it runs as smooth as it looks .
On a side note , I was wondering where Freddie Spencer's endurance racer wound up , now I know ... those were the days . Just a beautiful 1000R
- BLIGHT
Thanks, that's a nice compliment!67rschev wrote:What an awesome machine you have put together , probably my favorite chopped up GL on this forum . Nice thinking out of the box on the downdraft set up , hope it runs as smooth as it looks .
'76 GL1000
Blight, you stil around? How did this conversion work?
- BLIGHT
I'm alive.... the carb conversion works great. Better than my Mikuni flat-slide attempt!ericheath wrote:Blight, you stil around? How did this conversion work?
My clutch has weird issues of grabbing and making odd sounds on engagement.
I have not ridden it for a while due to this.... I got some new Barnett plates 'cuz someone thought the old ones may be warped.
No time to put 'em in right now, swamped with work 7 days a week. Maybe when things slow a bit!
It's a fun bike to ride, and pretty powerful for it's size. Handles well too, as long as you remember it's lean-angle limitations.
BLIGHT
'76 GL1000
When are you going to connect the two intakes like a VMax?? I always wondered if that would gain anything, but the more I've read, most feel that was a hokey gimmick on a bike that made awesome power either way.
- BLIGHT
Hi, I'm just kinda done tinkering with the old girl... it's fast enough for me with the bike's chassis limitations.ericheath wrote:When are you going to connect the two intakes like a VMax?? I always wondered if that would gain anything, but the more I've read, most feel that was a hokey gimmick on a bike that made awesome power either way.
My new love is a 2010 VFR1200..... 170 hp V4 and 95 ft-lbs of torque makes the scenery move verrry quickly!
[/url][/img][IMG]
BLIGHT
'76 GL1000
- 1475 Views
Last post by carolinacafe
- 28 Replies
- 1692 Views
Last post by Easter
- 7 Replies
- 576 Views
Last post by Whiskerfish
- 4 Replies
- 1591 Views
Last post by redglbx
