I do not know.
I know the ones I got from Honda had Stainless cir clips on them not black like Daiichi and most of the other After Market but I really doubt that is anything conclusive??
I looked at the frame and there is a manufacturer mark but I could not make it out. It was not the 3 propeller mark of Daiichi. These are an older set. 3-4 years or better I think.
some comments about the standard point ignition
Re: some comments about the standard point ignition
- mikenixon
- Early 'Wing Guru
- mikenixon
- Early 'Wing Guru
I see that David Silver Spares has been stockpiling original TEC points for various Hondas. Could be a good source for the original points for Wings too.
Mike Nixon
www.motorcycleproject.com
https://youtu.be/CDnzwDWhN24
- BlueThunder
Mike, have you noticed any difference between the Daiichi points and the aftermarket ones (as sold by David Spares)?
- mikenixon
- Early 'Wing Guru
Hi, blue. Not sure I understand the question. Are you saying there are two kinds of Diachi points? That I am not aware if. But here is an article you may be interested in.BlueThunder wrote:Mike, have you noticed any difference between the Daiichi points and the aftermarket ones (as sold by David Spares)?
http://www.motorcycleproject.com/text/i ... nders.html
Mike Nixon
- 6 Replies
- 319 Views
Last post by BlueThunder
- 7 Replies
- 257 Views
Last post by RB
- 7 Replies
- 227 Views
Last post by sunnbobb
