How to replace the driveshaft
kjeldbh
Zinc Member
Zinc Member
Post #1 by kjeldbh » Fri May 23, 2008 5:16 pm
My bike is a GL1000 '77 with original mufflers.
Last year the union joint part of the drive shaft did break. I bought a new one and new cir clips from CMS:
http://www.cmsnl.com/honda-gl1000-gold-wing-1977-us_model7391/partslist/F++22.html
This is how the driveshafts looks:
Next was to get the old one out and replace it with the new one. I had some trouble doing that, because I did follow the description from the shopmanual, which says that you have to remove the rear swing arm. I could not loosen the pivot bolts, and was looking for other ways, and managed to get the drive shaft out without removing the swing arm.
I removed the rear wheel and I removed the mufflers, too, which makes it possible to lower the swing arm so much, that I could pull the drive shaft out in the front end between the engine and the swing arm, an replace it with the new one.
The picture shows the new drive shaft on its way in place:
From this I have learned, in order to prevent an unplanned replacement of the drive shaft, it is highly recommended to follow Randakks inspection guide :
http://www.randakksblog.com/driveshalf-u-joint-inspection/
Regards Kjeld
tlbranth
Re: How to replace the driveshaft
Post #2 by tlbranth » Sat Jan 18, 2014 3:13 pm
Can we get the pictures restored to this thread?
Terry
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Sagebrush
Post #3 by Sagebrush » Sat Jan 18, 2014 5:11 pm
tlbranth wrote:Can we get the pictures restored to this thread?
Please read this thread: Gallery Upgrade Challenges
Post #4 by Whiskerfish » Sat Jan 18, 2014 5:12 pm
fixed, his post was about 15 minutes before I made the announcement.
SnoBrdr
Post #5 by SnoBrdr » Fri Sep 19, 2014 3:19 pm
Whiskerfish wrote:fixed, his post was about 15 minutes before I made the announcement.
So no pics? It's useless without them.
78 GL1000 Original Owner 129k
Who is online
Users browsing this forum: GLDCW and 0 guests
