7V Regulator
Moderators: robin1731, RAT, Forum Moderators
purplegoldwing
7V Regulator
Post #1 by purplegoldwing » Sun Nov 16, 2008 3:00 am
Here is another option for a 7V regulator that is working for me. I have about 300 miles on this now so far with no problems.
It is from Dimension Engineering. I just velcroed it in place.
I purchased their breakout board to mount it on. Makes wiring it in easier.
http://www.dimensionengineering.com/DE-SWADJ.htm
Bill
Naked custom 78 GL1000
1984 GL1200 Aspencade
2003 BMW K1200RS (for sale)
1985 GL1200 project: conversion to semi-standard
Pictures at:
http://www.flickr.com/photos/hubbell
Follow your heart, not the crowd!
Post #2 by sunnbobb » Sun Nov 16, 2008 3:12 am
OK, i need an explanation...
purplegoldwing
Post #3 by purplegoldwing » Sun Nov 16, 2008 12:56 pm
This replaced the 7 volt gauge regulator on my GL1000. The fuel and temperature gauges use 7 VDC instead of 12VDC to insure accuracy and stability. That way the gauges always have a constant voltage instead of fluctuating with battery voltage. Otherwise the gauges would typically drop at idle when the stator voltage dropped.
Uses three wires just like the original. Just have to wire it in directly instead of using the original plug. Just has three wires, battery voltage, ground and the output to the gauges.
This is mounted behind the left door/panel of the fake tank.
Bill
Pictures at:
purplegoldwing
Post #4 by purplegoldwing » Sun Nov 16, 2008 1:41 pm
Here is a picture of it in place. Note the high tech Velcro mount.
Bill
Pictures at:
Post #5 by sunnbobb » Sun Nov 16, 2008 2:07 pm
What is the picture in the upper right showing the regulator mounted on a board next to something?
FirstYearDeek
Post #6 by FirstYearDeek » Sun Nov 16, 2008 7:45 pm
Top left, first post is the finished package. Top right is the transistor they use, then the transistor on the board with the other components required to adjust the voltage.
Middle left and right are different views of the finished package.
Bottom left is a "breakout" board with a (very funky) 3-pole socket for the transistor. Bottom right is the package in the socket for a finished product that's easy to wire.
It's all a little "un-engineered" for me, but I like to pot stuff and would probably find a way to water-cool it or something!
-Deek
purplegoldwing
Post #7 by purplegoldwing » Sun Nov 16, 2008 8:16 pm
keeping it simple keeps the cost down, the regulator is only $15
Bill
Pictures at:
hiddenone
Post #8 by hiddenone » Sun Jan 11, 2009 12:07 am
thanks for the info! :-D
"Our true enemies, as well as our true sources of strength, lie within."
--Willaru Huayta, QUECHUA NATION, PERU
2-76 gl1000's
1-76 gl1000 LTD
1-parts 75 gl1000
RIP: 1950-2011
Post #9 by Cookie » Sun Jan 11, 2009 2:41 am
It looks like a tough little unit.
hallcm83
Post #10 by hallcm83 » Mon Apr 27, 2009 3:32 pm
going to have to try that on mine finicky temp readings and gas gauge is way too inconsistant
Christopher Hall GL1000 77' " Sgt. Fury"
http://www.nakedgoldwings.com/gallery/v ... /hallcm83/
Gl1000 78 "Project Mayhem" is underway just picked her up pictures to follow
purplegoldwing
Post #11 by purplegoldwing » Mon Apr 27, 2009 5:22 pm
It's been installed for awhile now and is still working. Noticed you are from Tyler Texas, I used to live there back in the late 70's. Is it still called the Rose Capital?
Bill
Pictures at:
hallcm83
Post #12 by hallcm83 » Tue Apr 28, 2009 4:48 am
Oh yeah still the Rose Capital it has gotten alot bigger but there are some great rides along this part of Texas.
Mike Toon
Zinc Member
Zinc Member
Post #13 by Mike Toon » Mon May 04, 2009 9:11 pm
Satisfied it worked, I gutted the old regulator and used epoxy putty to fill and hold things together. Installed back in stock place.
I had the parts, but bought at Radio Shack, about $3.00
Current Bikes
1981 GL1100 Naked
2004 KLR650
1988 KLR650
2001 DR650
1997 DR350
1984 XL350
2002 CB919
purplegoldwing
Post #14 by purplegoldwing » Thu May 07, 2009 11:58 pm
How did you get the old epoxy out? I tried that and destroyed the case.
That old epoxy is hard!
Bill
Pictures at:
Mike Toon
Zinc Member
Zinc Member
Post #15 by Mike Toon » Fri May 08, 2009 2:25 am
Drill press, drill press vice, gloves and a lot of patience.
Current Bikes
1981 GL1100 Naked
2004 KLR650
1988 KLR650
2001 DR650
1997 DR350
1984 XL350
2002 CB919
Who is online
