How to fix the dreaded "White Stator Connector"
jdvorchak
Post #1 by jdvorchak » Sat Apr 09, 2011 10:51 pm
NOTICE: Imageshack has lost my images and will only restore them if I upgrade to a paid account. I can not advise you to use Imageshack. Google or Photobucket seem to be free. I am in the process of trying to recover the images. Thank you for your patience.
I decided today to tackle the upgrade or fix for the white stator connector. While doing so I took some pics hoping someone might get some benefit.
The connector in question. Just to the left of the battery. Note battery ground disconnected. Always disconnect the battery when working on electrics:
Inside the connector. Hope you can see that the copper connectors are very dirty and corroded:
Another shot. Note the brown discoloration caused from heat. Heat is not your friend with electrical connections:
Note the brown heat induced discoloration. This in my opinion had already failed but we caught it in time:
Cut the wires from the connectors as close as you can get to the connector. Strip about 3/4 to 1 inch off the insulation and use the edge of a knife to make the copper wires shiny. :
Here is the soldering gun and solder you need for this job. Do not try it with a smaller soldering pen or thin solder.
You want 60/40 rosin core solder ONLY:
I couldn't hold the wires with one had and soldering gun with the other hand and solder with the 3rd hand and take the picture with what ever was left over so here is a quick tutorial on soldering two wires together. Start with stripping more than you think you need. About an inch:
Put some heat shrink tubing on before you connect the two ends of the wires. Twist both wires and lay one wire over the other at about a 90 deg angle
Begin by twisting one wire all the way around and over the other wire.
Now do the same with the remaining wire in this case the one on the right side now. Note that they are in a nice straight line with very little bulge:
When the soldering gun tip is hot just touch some solder to it to get the surface wet with molten solder. That helps the heat transfer to the wire joint quicker. Then place the tip under the wire.
Add the solder to the joint from the opposite end. The molten solder will flow toward the heat even up hill.
When it cools slide the heat shrink tubing over the joint and use a heat gun or match or cig lighter to heat and shrink the heat shrink tubing to fully insulate the joint.. Here is what it looks like before I tied it up with tie wraps. I added about 4 to 6 inches of #12 wire to make the whole process easier. Once you clip those connectors off there is not much play in the wires.
Now the final test the next 2pics are of the voltmeter engine on at idle and engine on at 2500 rpm. Yeah the 2500 rpm reading is a little high. I'll have to look into that. On the 1200 it's probably the sense wire (black) from the ignition switch to the fuse block. Also could be a poor ground on the regulator but I had just cleaned that connection a month or so ago.
Hope someone gets some benefit from this posting. As always I enjoy working on these things about as much as I like riding them.
page/ST
Amateur Radio Station WW9L
YIKES! Don't own a Honda at this time....
2010 HD Ultraglide Classic Limited
2008 HD Dyna Low Rider
83 KZ1100L1 Shaft
81 GS750EX
John
Re: How to fix the dreaded "White Stator Connector"
Post #2 by sunnbobb » Sat Apr 09, 2011 10:57 pm
VERY NICE!! Thanks! I like your cable splice too.
Graham Cracker
Post #3 by Graham Cracker » Sat Apr 09, 2011 11:44 pm
Great post! action1
"A man who carries a cat by the tail learns something he can learn no other way" - Mark Twain
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
1984 GL 1200 Black
Andyb
My Album: http://www.ngwclub.com/gallery/v/wingmans/Andyb/
Post #4 by Andyb » Sun Apr 10, 2011 7:30 am
[quote="jdvorchak"
Hope someone gets some benefit from this posting. As always I enjoy working on these things about as much as I like riding them.[/quote]
You know, I feel the same way. Working on my motorcycle is a great way to dissolve work stress.
Thanks for the great tutorial. I can see this happening in my future.
Andy B
1983 1100 Black and Red (used to be Interstate Regal Brown)
Bufobufo
Post #5 by Bufobufo » Sun Apr 10, 2011 4:47 pm
And also look further up at the connectors by the regulator. On my 1200A one phase of these burnt badly and marked the inside of the 'tank' cover. Luckily it never burnt through to the outside.
Hardwire or clean up and protect with dielectric grease.
JohnR - 76 GL 1000 Yellow Bird - in Cold Old England.
cmonSTART
Post #6 by cmonSTART » Sun Apr 10, 2011 5:59 pm
Good post! Exactly what I am going to do on my project '81. The connector had a melt down.
1983 GL1100I - Fully Dressed!!
1978 CB750F Perpetual racer project
A few odd 76 GL1000s also - I swear it's a disease!
Post #7 by Roady » Sun Apr 10, 2011 6:58 pm
Excellent post, JD. It gives me the confidence to go ahead and do mine.
Moving this to the How-To forum and into ShopTalk.
Hal
Post #8 by Hal » Sun May 01, 2011 5:39 am
Sounds like a good idea to me also.
One question, where did you put your meter probes?
The PO told me he thought the stator on my '76 bike was probably shot, but when I checked it yesterday I was surprised to see a healthy increase in the voltage measured across the battery terminals, rising to 15 volts at 4000 rpm!
This is surely way too high, what should I look at checking next? Is the voltage regulator likely to be on the way out?
I'm a bit rubbish as far as electrics are concerned, as you may have guessed! :mrgreen:
nor all your Piety nor Wit
1977 GL1000 in bits
1978 SR 500 Yam
2003 V-rod Anniversary brushed alu (for sale)
1993 'Big Valve' BMW R1100RS "Red Sonja"
Hal's Nalbum
old farmer
Lead Member
Lead Member
Post #9 by old farmer » Sat Apr 21, 2012 9:56 pm
Hi I have a question about this, does it matter which wire is connected to which and if so how did you keep track how to reconnect them?
my connector on my 78 is melted down
Post #10 by robin1731 » Sat Apr 21, 2012 11:07 pm
old farmer wrote:Hi I have a question about this, does it matter which wire is connected to which and if so how did you keep track how to reconnect them?
Nope, doesn't matter which wire is connected to the other.
1975 GL1000 parts bike (parts for sale)
Sagebrush
Post #11 by Sagebrush » Sun Apr 22, 2012 8:46 am
Hal, chances are you have a bad (resistive) ground to your voltage regulator or the main ground to the bike in general. First clean up all the connections to the battery, frame ground and while your at it starter relay. If your connector to the stator looks compromised in any way then splice them like in the tutorial. Now move to your voltage regulator and make sure all the connections to it are clean and secure. And finally determine which wire is ground to the regulator and make sure there is no resistance to the frame. Sidecar Bob has large color wiring diagrams in his gallery suitable for downloading. If there is any resistance on the ground wire then the reference to the voltage regulator is bad and is causing it to charge at too high a voltage. If you can't get it cleaned up you may be able to splice in an additional wire and run it to a known good ground location.
old farmer
Lead Member
Lead Member
Post #12 by old farmer » Mon Apr 23, 2012 7:36 pm
thanks Ill check alll of that stuff , Iam new to this type of bike so am learning fast this site has been a great help thanks to all !
SnoBrdr
Post #13 by SnoBrdr » Sat Jul 21, 2012 9:42 am
I don't get it.
What is that wire loop for and where does it go?
From the picture it looks like you just eliminated the connector and ran it wire to wire.
Please correct me if I am wrong before I attempt this.
78 GL1000 Original Owner 129k
Post #14 by Roady » Sat Jul 21, 2012 1:19 pm
Yes, you want to cut the connector out and solder the wires together. It doesn't matter which ones you connect together, it's just yellow-yellow, yellow-yellow, yellow-yellow. He added the extra white wire because there wasn't enough length, some do have enough to connect them directly together.
SnoBrdr
Post #15 by SnoBrdr » Sat Jul 21, 2012 1:49 pm
Roady wrote:Yes, you want to cut the connector out and solder the wires together. It doesn't matter which ones you connect together, it's just yellow-yellow, yellow-yellow, yellow-yellow. He added the extra white wire because there wasn't enough length, some do have enough to connect them directly together.
Ah, thanks
Who is online
Users browsing this forum: acestrom, GLDCW and 0 guests
