replacing stator with $40 GM alternator
jake2012
Post #1 by jake2012 » Tue May 29, 2012 10:08 pm
I know how we like pics so here are some of a GM alternator installed under faux tank. Most know how expensive stators and related electronics are so this is a cheap alternative and excellent working replacement. This is a pic of it mounted crossy.gif
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1977 custom hawg chopper
1952 Pan Shovel
2x 76 gl1000s
jake2012
Re: replacing stator with $40 GM alternator
Post #2 by jake2012 » Tue May 29, 2012 10:09 pm
Another view. The stack is 2 stacks cut off original air cleaners and welded together. Unlike the poor boy kit she puts out 14.62 volts at idle with the 5" bottom pulley. and it looks better.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
jake2012
Post #3 by jake2012 » Tue May 29, 2012 10:24 pm
I had to modify the tool tray so it would reach and seal on the stack
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
jake2012
Post #4 by jake2012 » Tue May 29, 2012 10:25 pm
Air cleaner installed
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
jake2012
Post #5 by jake2012 » Tue May 29, 2012 10:31 pm
Bought a $12 pulley from tractor supply and pinned it to the timing belt pulley. The belt was $6 from Napa. I had to grind the fins down on timing covers and left out the gaskets so as to not have to kick the radiator out to much.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
jake2012
Post #6 by jake2012 » Tue May 29, 2012 10:33 pm
I just finnished grafting in some louvers for better air flow to filter.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
jake2012
Post #7 by jake2012 » Tue May 29, 2012 10:42 pm
The rad is kicked out about 1 1/4" and still room to remove belt.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
jake2012
Post #8 by jake2012 » Tue May 29, 2012 11:02 pm
Bought a $15 10" fan from Amazon and it fit and works perfect.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
Zacsdaddy
Post #9 by Zacsdaddy » Tue May 29, 2012 11:51 pm
Dang good lookin' modification.
Zacsdaddy
1981 GL1100 That Mama found and bought for me.
1975 KZ400D That I found for Her and brought back to life.
"If the Women don't find you handsome, they ought to at least find you handy" - Red Green
Dangeruss
Post #10 by Dangeruss » Wed May 30, 2012 12:00 am
Very nice, looks like a shoe horn fit, but the results are excellent. anim-cheers1
Russ
77 GL1000
82 CB900F
83 CB1100F project
States visited by Goldwing...
Boufie
My Album: http://tinyurl.com/2dma28f
Post #11 by Boufie » Wed May 30, 2012 12:00 am
WOW, that is one SLICK modification...
John B.
1978 GL1000
Post #12 by sunnbobb » Wed May 30, 2012 1:59 am
My hat is off to you!
Post #13 by ericheath » Wed May 30, 2012 7:33 am
How'd you pin the pulley? Any photos of that? Nice clean mod.
77 WING, 1200 engine with 77 heads, cams, gl1100 foot pegs, Magna V65 front end, 764A carbs, Suzuki M109 monoshock, gl 1200 swing arm, gl1500 final drive, wheel and rear brakes Valkyrie seat, Meanstreak tank, Sportster pipes, Power Arc ignition off crank.
aussiewingman
Post #14 by aussiewingman » Wed May 30, 2012 7:54 am
looks excellent work...
i do have a simpletons question....
what do you do with the other alternator that the bike has?
Post #15 by robin1731 » Wed May 30, 2012 8:20 am
aussiewingman wrote:looks excellent work...
Usually nothing. It doesn't hurt anything to just leave it in there.
1975 GL1000 parts bike (parts for sale)
Who is online
