Intermittent ignition problem
- Brass Member
Hey there everyone. I have a problem that I haven’t been able to solve, and I’m hoping that someone out there has had a similar issue.
Background: Bike is a 75 goldwing that I’ve rebuilt over the last 2 years. No real modifications, other than Harley exhaust. Bike was basically down to engine and frame a few months ago. Carbs cleaned and rebuilt, belts changed, brakes rebuilt, tank cleaned, electrical all hooked back up, timing cleaned and reset (split timing method), valves done, etc. Everything that needed to be done to get a bike going after 10+ years sitting.
I got the bike started and tuned quite nicely. It fired right up with minimal choke, idles nicely and drives like a champ. It’s actually surprising how fast it is for an old bike. I thought the speedometer was off when I was doing 80mph. Didn’t feel like at all close to that. I later confirmed that I was indeed pretty accurate. Yikes! Good thing I didn’t get a ticket!!
Here’s the problem: I’ll be driving along (highway speed, or around town, doesn’t really matter) and I’ll lose all ignition. Lights are still on, kill switch in the run position, but no power or spark. Sometimes it’s a second or two, others, I need to pull over and try to restart it. Sometimes it restarts right away, other times it takes 10 seconds before it will fire up (and all other electrics are functional), sometimes I need to let it sit 30 sec or more.
Here’s what I’ve done so far:
- checked battery connections and all the connections for the electrics around the battery.
- checked the ground by the coils. It was in an obvious place, so cleaned and tightened.
- changed the regulator (took it from the parts bike I have.
- the kill switch was cleaned as part of my rebuild process, but hasn’t been checked since.
Intermittent problems are such a pain, and electrics are not my strong suit. I’m hoping someone has a direction or two for me to check. Thanks in advance guys!
Here’s what she looks like at the moment, in case anyone is wondering. Good ol naked Goldwing w flat bars and brat seat.
Carter
1980 CB650 Custom
1975 GL1000 “F4B”
1980 CB650 Custom
1975 GL1000 “F4B”
Re: Intermittent ignition problem
there is a possibility that the cover over the points is to tight, or the gasket is from time to time. not thick enough. Causing the cover to short out the points. Heat expansion causes the cover to expand, and touch the points. When it cools down a bit. it works. Easy to test. Try running without the points cover on
- Brass Member
I never would have thought of the points cover. I will try that!
Carter
1980 CB650 Custom
1975 GL1000 “F4B”
1980 CB650 Custom
1975 GL1000 “F4B”
I have not seen it to often, but could be, and is easy to check. If, as you say, everything else checks out,.....can't hurt
- ritalz
I had a similar symptom a while back on my 75. Turned out to be the ignition switch connector was loose and would vibrate enough to break contact. Found that one by accident.
I had to replace a bad ignition switch for that. I could wiggle the key and it would come back. For a while...
- todd54219
I had an issue with a fuse. Mine would just shut down like yours. Sometimes restart. The last time it failed I had to push it about 1/2 mile. It checked out good in the fuse block. When I pulled it, it fell apart. For a few dollars, replace all of the fuses.
Good luck and let us know what you find
Todd
Todd
Todd54219 - Common sense is not so common anymore
1976 Yellow GL1000
1966 White Honda CA95 (Baby Dream) under restoration - Done and sold
1976 Yellow GL1000
- chewy999
I've had a fuse do that, tested fine but the vibration when riding must have broken the circuit. When I took it out the end fell off. Changed all the fuses for a few £. Easy to miss, but easy to fix when found.todd54219 wrote:I had an issue with a fuse. Mine would just shut down like yours. Sometimes restart. The last time it failed I had to push it about 1/2 mile. It checked out good in the fuse block. When I pulled it, it fell apart. For a few dollars, replace all of the fuses.
Todd
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
Yeah, if you are using the original "dogbone" main fuse it is highly recommended to replace it with an inline fuse holder and a modern blade type fuse so that you can get a replacement anywhere if you blow the fuse while away from home.
Also, how old are your condensers? I had a bike years ago that would do what you describe and once I replaced the condenser it stopped doing that.
- Brass Member
Thanks for all the replies/ideas. I have a list of things to check now... I’ll check the kill switch connections in the wiring, the fuses (I’ve already replaced some, but not all), try the points cover, check the main fuse, and the condensers. I don’t know the age of the condensers, but I have a parts bike so I can swap out and test ride. I should have some time this weekend, so I’ll update here once I have a chance to!
Carter
1980 CB650 Custom
1975 GL1000 “F4B”
1980 CB650 Custom
1975 GL1000 “F4B”
Flatlander80 wrote:Thanks for all the replies/ideas. I have a list of things to check now... I’ll check the kill switch connections in the wiring, the fuses (I’ve already replaced some, but not all), try the points cover, check the main fuse, and the condensers. I don’t know the age of the condensers, but I have a parts bike so I can swap out and test ride. I should have some time this weekend, so I’ll update here once I have a chance to!
New condensers don't cost that much. I hear people all the time that say change points but no need to change condensers. (Not saying anyone said that here) But when putting in new points you should always put in new condensers too. they will wear out. Cheap and easy to do.
Maybe try your used ones just to see if it makes a difference but I would put new ones in when you get the chance.
Since you still have power elsewhere when it dies I doubt it is the main fuse. Easy to check though and a good idea to update to a more modern blade type main fuse. I've seen original type main fuses look good but fall apart when you try to remove them.
When you do replace the condensers with new, don't buy them from the Honda dealer. Generic condensers from a car parts place might need a bit more fiddling to mount the first time but the will cost a small fraction of buying what is essentially just 2 condensers in a mounting bracket. You might be able to find somewhere more convenient to mount them too.
I think what Al was talking about above is the ignition switch multi-pin connector up in the triple underneath the ignition.
I've had it happen. the little plastic clippy clasp part that keeps it from being removed or dislodged without pressing the release part, broke off.
the connector pushes upwards into the receptacle.
it's kinda hard to get at though.
H2G2=42
H2G2=42
If you suspect a condenser may be involved, please be aware that particular ignition component's mounting bracket must be sufficently grounded to its mounting surface to work as it is designed to.
Read this article from Randakk's GL1000 tech blog.
http://www.randakksblog.com/gl1000-cond ... /#more-610
Also, whether your ignition utilizes the original breaker points set-up or otherwise, a low resistance grounding of the baseplate onto the engine mounting surface is of great importance, as well.
Scroll down to the bottom of this page to find SIMILAR TOPICS.
Cliff (74yrs )
- desertrefugee
I would not expect a condenser to fail in such a way that it's intermittent. It's a capacitor. They either work or they don't. Most fail in a shorted state - in which case you'd have dead ignition. I don't think I've ever seen a truly intermittent capacitor. The +12V primary ignition feed (Black/White) is definitely suspect. As noted, it feeds through the Ignition Switch, but also routes through the START/STOP switch and the ballast resistor on its way to the both coils. I once had a flaky spade connector on a ballast resistor that caused me some ignition grief. You could hot wire it for a short ride to see how it performs. If it's better, obviously there are issues with that line.
- 28 Replies
- 2500 Views
Last post by NCScooter
- 20 Replies
- 724 Views
Last post by roachb
- 21 Replies
- 752 Views
Last post by Sidecar Bob
- 29 Replies
- 1855 Views
Last post by ericheath
- 39 Replies
- 884 Views
Last post by Easter
