sudden loss of power
Moderators: CYBORG, robin1731, Oldewing, Forum Moderators
sickradsean
Re: sudden loss of power
Post by sickradsean »
The new coils showed up today and I got right into stipping off the shelter to get to the old ones. As I understand it you just remove the two mounting bolts from the coil bracket and pull the whole thing out (disconnect the wires first)? How do you all suggest I remove the lower bracket bolt? This thing seems impossible to get to, the wiring harness and all the cables are routed right in front of it!
After that just bolt up the new coils to the bracket, change the connectors on the wires to the crimp ring connectors that were provided and screw into the terminals on the coil, make new spark plug wires. Do I need to keep the resistor or with these new coils it's not necessary? The wires that came with the kit seem to be non resistor wires.
1977 GL1000 "Goldie"
sickradsean
Just caught the (*) at the end of Octanes post on the coil install. So no resistor, but does it matter which wire goes to which coil? I get that the plug wires don't matter (side to side) but does it matter which wire (that used to go into the resistor) goes into each coil?
sickradsean wrote: Fri Oct 22, 2021 1:32 am Just caught the (*) at the end of Octanes post on the coil install. So no resistor, but does it matter which wire goes to which coil? I get that the plug wires don't matter (side to side) but does it matter which wire (that used to go into the resistor) goes into each coil?
Those two wires, that were originally connected to either end of the ballast resistor, are then connected together to complete the +12vdc supply circuit that feeds the Off/Run/Off handlebar switch.
sickradsean
So connect the two wires from the ballast resistor together and then the blue wire to one coil and yellow to the other? Do I still need to ground the unit? When I was taking off the mounting bolt it had a green wire solder lug on it.
sickradsean
So after MANY attempts to get the lower bolt off i finally stumbled on this old wrench i got from my grampa. It's a 1/4" drive socket with an elbow that I put a 10mm socket on. Got that bolt out 1/4 turn at a time! When I reinstall I plan on using stainless socket head screws to make it easier to get in there.
I then followed the instructions on the Dyna coils and got them wired up. I clipped the old wire leads off the old coils and soldered the ring lugs onto the new coils and installed them on the mounting bracket. I did have to file the bracket a lil bit to let them fit. Apparently the Dyna mounts are like a 1/32 larger than the stock coils.
So now it's just mount the assembly back on the frame (with the ground lug on the frame mount) and reconnect the coil wires to the harness. I connected the two black/orange wires together that would have gone to the ballast resistor and then its yellow to yellow, blue to blue, and the two black/white go to the one double plug black/white on the harness.
I think that's all right, right?
sickradsean
Got those new Dynas on and wired back up. Cut the ignition wires and spliced them back onto the NGK boots (all with a good helping of electrical grease). While i was all in the wiring harness I repaired a few, let's say "creative", splices the PO had done (just think zip ties and electrical tape). When I went to test if the coils would fire this is what I got:
https://flic.kr/p/2mELVfy
That is A LOT of post engine backfire! You catch the flame in the first few?? I'm stumped as to why a machine that was running tip top 4 weeks ago is now at this stage?! It will seem to smooth out if I can start it and keep the RPM above 3000, so that leads me to believe the idle circuit is clogged? Since I've replaced the coils do I HAVE to reset the timing? Many questions, I know.
My next course of action would be to start at the beginning again. Belts, timing, valves, carbs (particularly idle jets, floats, and needles), unless someone can point me in another direction. confused22 confused22
MattMcCoy
Post by MattMcCoy »
MattMcCoy wrote: Thu Oct 21, 2021 9:32 am My guess would be dirty idle jets, if opening the throttle and increasing RPMs keeps it running.
You might try this to see if it helps:
https://www.motorcycleproject.com/text/ ... _bike.html
1983 GL1100A Aspencade
1977 GL1000
1978 GL1000
1979 GL1000
“I see Angels on Ariels in leather and chrome,
Swoopin' down from Heaven to carry me home."
Make sure the plug wires are all connected properly. Plugged jets won't cause a backfire like that.
sickradsean
robin1731 wrote: Thu Oct 28, 2021 10:26 am Make sure the plug wires are all connected properly. Plugged jets won't cause a backfire like that.
I posted a pic of how I wired the coils above. It was my understanding that it didn’t matter which terminal the plug wires were connected to as long as you don’t cross over sides (one coil is for cylinders 1&3 the other for 2&4). Is that what you mean? Or literally “they are all plugged in”?
MattMcCoy
Post by MattMcCoy »
I believe you have a new issue due to wiring. One coil should be 1&2 and the other 3&4 (front/back).
1977 GL1000
1978 GL1000
1979 GL1000
What he said. ^^^^^^^
(Drawings courtesy of Randakk, applicable to all 4 cylinder GoldWIngs)
sickradsean
#28
YES!! That was it, I miswired the plug wires. Switched them over to the above drawing, the bike fired right up and is purring along nicely. I think a new set of plugs and some highway miles should get everything back in order. You all are a bunch of Goldwing guardian angels. Thanks for saving my butt again! anim-cheers1
#29
tumb2 tumb2 tumb2
sickradsean
#30
A quick 10mi shakedown ride reveals it wasn't the coils after all! After running beautifully for about 9.5 of those miles the engine started acting like it was absolutely starved for fuel (plenty of gas in the tank). So now I know it's not the coils, wires, plugs, fuel filter, fuel line, or fuel pump (that would either fail or be fine, not randomly cut in and out?). What else would lead to an intermittent problem like this? Crap in the tank blocking the gas flow, stuck butterfly not opening, crap in the carbs clogging the jets, clogged petcock? I feel like its a fuel delivery issue. I'll try blasting out the carbs again to see if that changes anything, after that I feel I will just have to pull the rack and open them up.
