Disclaimer - Electricals are my weakness
The headlight on my naked '81 1100 is not working. After pulling off the Vetter fairing, I mounted a new aftermarket light from 4into1 which worked recently on this bike but stopped working during a ride this past week. After checking the common cause (fuse, loose wiring) I tested a known working headlight from a GS550, which also didn't light up. There does not appear to be any juice making it to the three prong light connector, so the problem is somewhere upstream of that.
The fuse is receiving juice and the tester lights up on both sides of the fuse. All other lighting works (signals, rear light, f/r brake light, horn, etc.). the only other electrical issue is the rear suspension pressure light is always on since I removed the shocks and haven't (yet) grounded the wire. I can't imagine that should impact the headlight .. famous last words.
The LH control seems fine (see pics) with no apparent loose wires or excessive corrosion. Does the switch rely on the positioning nub and hole in eth handlebar for grounding?
Any ideas or other things to check?
diagnosing headlight woes
Moderators: CYBORG, robin1731, Oldewing, Forum Moderators
Greater Boston MA, USA
Stable as of 15May22: '81 GL1100, '10 Bonnie SE, '81 Suzuki GS550T, '83 Suzuki GS650L, '14 Moto Guzzi California
Re: diagnosing headlight woes
Open up your starter button control and spray it out good with some contact cleaner. The power for the headlight goes through that.
Thanks, I was not aware of that. I need to make a beer run and the HW store is (not surprisingly) near the beer store.Whiskerfish wrote: ↑Sat May 14, 2022 12:10 pm Open up your starter button control and spray it out good with some contact cleaner. The power for the headlight goes through that.
UPDATE - Yep, contact cleaner on the starter button fixed it, as shown by the ring of fire on the towel in the pic below. Awesome advice.
Another thing to care for NOW: Vetter supplied their fairings with the worst electrical connector ever produced - the Scotch-lok. Not only poor contact, but severs wire strands and ruins the insulation. Find each one of the wounds to your wiring made by them and check for cut strands. If they are cut, re-splice properly. This is particularly important on the high current headlight wiring. Heal cuts in the insulation with shrink tubing or liquid electrical tape.
1972 Triumph T150V Trident rescue - in sad shape
Already done. I left one or two of the hard to reach Scotch-Loks in place and simply cut the wire instead.pidjones wrote: ↑Sun May 15, 2022 8:34 am Another thing to care for NOW: Vetter supplied their fairings with the worst electrical connector ever produced - the Scotch-lok. Not only poor contact, but severs wire strands and ruins the insulation. Find each one of the wounds to your wiring made by them and check for cut strands. If they are cut, re-splice properly. This is particularly important on the high current headlight wiring. Heal cuts in the insulation with shrink tubing or liquid electrical tape.
I'll double check today since I have to fix a minor wiring issue with the instrument panel signal indicators.
Ìs the GL1100 starter button headight contacts as vulnerable to overload as the GL1000 starter button headlight contacts are?
12volt relay installation a proactive consideration on this model, too?
Me Too!!
October,2017 BOTM
October,2017 BOTM
- 2 Replies
- 55 Views
Last post by Scottinaz
- 8 Replies
- 170 Views
Last post by zman
- 18 Replies
- 158 Views
Last post by hutch
- 7 Replies
- 114 Views
Last post by backyardbob
