sticking 2-4 synchronizer linkage 'fix' ; attributed to PISTOL PETE <<AND>> MAURY, TOO!!
Moderators: robin1731, Oldewing, CYBORG, Forum Moderators
Didn't know what other catchy words might be used to locate by search title this gem of 2016 Pistol Pete carburetion mystery sleuthing . not related to Randakk's mispositioned special flat washers tech tip.
maury is the Club member you must thank for this original Topic action1
https://ngwclub.com/forum/viewtopic.php?f=1&t=61242
maury aptly termed it, the 'Mysterious Honda High Idle Problem"
Cliff (74yrs ;) )
pidjones
Re: sticking 2-4 synchronizer linkage 'fix' ; attributed to PISTOL PETE
Post by pidjones »
Pete was a true gentleman.
I wish I had seen that when it was posted. I started experiencing a similar issue on July of the same year but nobody had any suggestions that worked. In September (not long before Maury posted his solution) I I came back to that thread to say that I had learned that I could "fix" the issue temporarily by pushing on an adjuster screw.
viewtopic.php?f=1&t=60859&p=672149&hili ... ot#p672149
The issue has persisted after replacing the engine so I was pretty sure it was a carb linkage but I went over then several times and couldn't find anything and concluded that it was just because they were old and worn. I have bookmarked Maury's thread so I can try Pete's solution when I eventually get Mr.H out of storage.
I added Maury's post to ShopTalk under the Carb sync section and called it Mysterious Honda High Idle Problem. Nice to have it captured. Thank you Cliff for digging it up again. (edit by Fred on Cinco DeMayo 2023)
'Mysterious Honda High Idle Problem" tumb2
Cliff (74yrs ;) )
tumb2 tumb2
Cliff (74yrs ;) )
Me too. If it is the same thing mine does I wouldn't call it "dancing". It idles normally when cool and then increases (almost as if the choke's high idle was engaged) when hot.
maury
Post by maury »
I'm famous !!
76 GL1000 LTD
2019 DCT Airbag Tour
Austin, Texas
Re: sticking 2-4 synchronizer linkage 'fix' ; attributed to PISTOL PETE , AND MAURY!!
maury wrote: Fri May 26, 2023 4:20 pmI'm famous !!
action1 action1 YES! YOU ARE !!! tumb2 tumb2
Cliff (74yrs ;) )
