On my '77 GL1000 the front stock running light are very bright. When the left or right turn signal is activated the running light goes out ok but the turn signal flashes very dim.
The rear turn signals are very bright when they flash, why aren't the front turn signals as bright?
The 1157 bulb used in for turn signals normally on a car uses the brightest element for turn signal and the dimmer element for tail lights. Why don't the same bulb do the same thing on the front of a motorcycle?
Question about front turn signals.
- Dane
- Zryder
- My Album: http://www.ngwclub.com/gallery/v/wingmans/zryder/
Ive seen that Dane , but the fellow had the wiring backwards for those signals at the front , switch them back and see what happends . That was his problem anyways , just one idea , ( Z )
1982 GL 1100 std. Custom
or make sure that all the connectors are making good contact.... a corroded connector will act as if it is not connected at all, or be intermittent
- Zryder
Right on Dane I love it when a plan comes together ( Z )
- QUEEENlE
Woo hoo .... good call guys.
Hugs
Q
Good job Dane!
Hugs
Q
Good job Dane!
- 229 Views
Last post by SnoBrdr
- 15 Replies
- 464 Views
- 4 Replies
- 214 Views
Last post by avg_joe
- 14 Replies
- 1025 Views
Last post by mcgovern61
