I just finished some carb work today and synched the carbs with this device (manometer) I've used for years. It is from a Beemer Airhead site and has been around for a long time. If you might be interested, check this out. It finds a perfect balance between two carbs. At the bottom of the article there is a link to a drawing
http://www.airheads.org/content/view/183/49/
If you like the idea and want to try it out, you have to make adapters for the Goldwing carbs. Here's what I did: First locate two 4mm screws and drill a sixteenth inch hole through the length of them, cut off the heads and push them into a 4 inch length of the same tubing used for the manometer. Then thread on a 4mm nut followed by a small o-ring. In the other end of the short tube, insert a sleeve which will connect the adapter to the manometer tubing. PM for more info.
Here's a Do-It-Yourself carb synchronizer that really works
- muser3
Muser3
The older I get the better I was.
East Texas
77 GL1000 Naked
78 GL1000 Vetter Fairing
80 R100RT
94 R1100RSL Black
94 R1100RSL Pearl Silver
Boxers All
82 Suzuki GS1100 gone to new OK home.
East Texas
77 GL1000 Naked
80 R100RT
94 R1100RSL Black
Boxers All
- muser3
By the way, don't let the "two carbs" thing turn you off. to balance four goldwing carbs, you first balance the left bank, then the right bank, then the rear carbs on each bank to get a balance of all four carbs.
Muser3
East Texas
77 GL1000 Naked
80 R100RT
94 R1100RSL Black
Boxers All
East Texas
77 GL1000 Naked
80 R100RT
94 R1100RSL Black
Boxers All
- quakeholio
- muser3
You could do that but I find the "Two at a time" balancing to be very effective. Since you are comparing carb to carb rather than meter to meter, you are a LOT more accurate I think.
Muser3
East Texas
77 GL1000 Naked
80 R100RT
94 R1100RSL Black
Boxers All
East Texas
77 GL1000 Naked
80 R100RT
94 R1100RSL Black
Boxers All
- Zacsdaddy
This sounds like my kind of project!
The hose they're talking about uses plastic barb fittings. Just find the size that the barb will "screw" into the fitting on the side of the intake. Use reducers if you want bigger hoses to make it easier to see. Put inline fittings on carbs 1 and 2 and "T" fittings on carbs 3 and 4 then make 3 "gauges".
The levels don't have to match they just have to be level to themselves.
1 = 3 and 2 = 4 and 3 = 4 so all are balanced. Does that figure right?
I may be doing this tomorrow.
Zacsdaddy
Zacsdaddy
1981 GL1100 That Mama found and bought for me.
1975 KZ400D That I found for Her and brought back to life.
"If the Women don't find you handsome, they ought to at least find you handy" - Red Green
- 18 Replies
- 741 Views
Last post by Sidecar Bob
- 3 Replies
- 356 Views
- 10 Replies
- 634 Views
Last post by gltriker
