Bought a set from a member but I let them lay over and the oil ran out. Air hoses were disconneted. Anyone know how much oil and what weight?.
Were these good shocks when new? DaveJ
SW Mark III air shocks for the rear.
- Dave_J
Retired US ARMY Signal
Old Mopars TT 65 B-Cuda in the works, 78 Dodge LRT with 425 HP 360
80 GL-1100 Faux Interstate
03 Suzuki Burgman 650 Supersized Scooter - Darksided Potenza Car Tire on the rear
- TomE
- My Album: http://www.ngwclub.com/gallery/v/wingmans/TomE/
I think he meant it ran out the disconncted top fitting. I have no clue how much were in them
- Dave_J
My son doesent think there should be any oil in the "AIR" part of these. Makes some sense, in all of the 70's and 80's car AIR shocks, the oil was seprate from the air chambers. He thinks that the oil seals have failed. I don't know. Good thing I dident pay too much for them. DaveJ
On 82 stock air shocks the oil will run out where the air tubes attach.
They apparently share a common space. If all else fails you could try same amount of oil as stock GL1100 shocks.
Just an idea.
Claude
Just an idea.
Claude
so a real quandry here..... was the oil in the s$w's seperate from the air or not..... well, I am not turning mine upside down to find out
- WShie
No, the oil is supposed to be there. Since oil is not compressable the oil was used to change the damping curve of the shocks. More oil I believe was added to cause the shocks to firm up faster when being compressed under a heavy load. There was a "special" S+W oil that was used and was only to be added in very small amounts (5cc) at a time until you had the curve adjusted to your liking. I don't know how much oil is supposed to be in there, but if you were to drain them completely and then add a small amount of oil initially (maybe 25ccs or so) and see what your damping curve is like you could go from there. I would think you could use a light oil like ATF IMHO, but there may be a source for the S+W oil out there someplace.
Bill
1979 GL1000- On the road again after 19 years
1980 GS1000G Current Moneypit.. er project
1976 KZ400- Winter Project
Gone but not forgotten:
1941 Matchless 350
1956 BSA Golden Flash
1956 Triumph 650
1977 Moto Guzzi 850T
1979 Yamaha XS1100
1941 Matchless 350
1956 Triumph 650
1979 Yamaha XS1100
s$w hasn't been made in years, so I would suggest ATF, it is what almost all shocks use
- Dave_J
Oil in SW shocks
I have looked at both shocks and there looks like there never has been oil in the AIR chamber. The oil on the floor and in the wifes Buicks trunk may be from my front shock tubes that were also laying down flat, also with the air hoses off. I did inflate the rears to about 50 PSI and the left one does not extend as far as the right side one. DaveJ
- 6 Replies
- 444 Views
Last post by Goboy
- 6 Replies
- 761 Views
Last post by Sidecar Bob
- 14 Replies
- 469 Views
Last post by wingrider
- 164 Views
Last post by Whiskerfish
- 237 Views
Last post by rcmatt007
