I am looking at new Master cylinders as the site glasses are leaking and i cant seem to get them to stop i have remade them with ca glue and watch faces but no luck its leaking again.
http://www.miniurl.com/s/1OF
That is in my price range and looks like i want the only thing i NEED to know is will it bolt up directly?
Thank to all of you in advance,
James
Will This work for my 1984 GL1200 Interstate
- jvacustoms
- My Album: http://www.ngwclub.com/gallery/v/wingmans/jvacustoms/
1984 Gl1200 Goldwing Bagger (~*~Phoenix~*~) - Rests in Pieces Awaiting a grand rebirth
1976 Gl1000 Yellow - Might just be Phoenix new shell for rebirth.
I was here but now I'm gone, I left some rubber to turn you on !
James Ammons
U.S. Army Combat Veteran
OIF3 & OIF4
James Ammons
OIF3 & OIF4
Re: Will This work for my 1984 GL1200 Interstate
its designed for a 7/8 bar, so should be fine. i would make sure the threads on the banjo hook up were metric, or it cames with a banjo bolt. harley threads are different
Says right in the info section, M10x1 outlet thread.
Check yours to make sure it is the same. Magura makes good parts. I use them on the race bikes. There is no brake light switch on that M/C. But if you use the stock 1000 switch you'll be good.
- phaserburn
- My Album: http://www.ngwclub.com/gallery/v/wingmans/phaserbu
You can try to fix it yourself if you care little for looks. You can use a dime and JB weld (I did it on one of mine and lasted 1000+ miles before I found something better).
You can try this too:
http://www.ebay.com/itm/85-86-VT1100-VT ... d6&vxp=mtr
What did you use for a faux tank cover? Have any more pics of your bike?
J
J
1983 Honda GL1100 Bagger
2015 Super Tenere
2018 Ducati Desert Sled
http://www.ngwclub.com/gallery/v/wingmans/phaserburn/
2015 Super Tenere
- 39 Replies
- 17284 Views
Last post by ready set go
- 4 Replies
- 879 Views
Last post by Wargoat
