Hi all - replaced water and housing with another pump that was tight- no wobble. the old one was really a wiggler. new pump is leaking very consistently..... any ideas what could be wrong before I rebuild the pump? ...thxs kenai
it is leaking water (distilled -as new head gaskets being broke in); pump is not wobbly so i'll chase a pinched oring/gasket. pulling it out the second time should not be so bad; 1/4 drive impact wrench plus all the fittings are anti-seized
77 gl1000 - water pump leak
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
1 - 1978
1 - 1977
1 for parts
Re: 77 gl1000 - water pump leak
Leaking coolant or oil?
- Placerville
Yes, it's a bad pump, replace it. Don't rebuilt it. It's not worth the effort or the cost savings.kenai wrote:..... any ideas what could be wrong...
- RB
If water out the weep hole pinched o ring if not bad pump bearings..green is oil blue is water.
- ALL WATER LEAKS.jpeg (32.88 KiB) Viewed 304 times
- ALL LEAKS.jpeg (37.96 KiB) Viewed 304 times
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- Placerville
Good call by RB. Either way, you get to pull the pump out again.
until you pull it and look, you cannot tell if it is the O-ring.... here is the thing, however, if you pull it replace the O-ring and it still leaks you will have to pull it again.
what I am not sure from your orginal question is whether the pump you put in is new or used
- Placerville
Sounds like a used pump to me.... Kenai, your going to have to take it apart again to replace that O ring and, maybe again if it's a bad pump. Do yourself a favor and simply put in a new pump. Use parts in this situation are not the way to go. Just too much work.kenai wrote:....replaced water and housing with another pump that was tight- no wobble.
- 12 Replies
- 819 Views
Last post by elslimdiablo
- 39 Replies
- 3335 Views
Last post by Rat
- 3 Replies
- 637 Views
Last post by Sidecar Bob
- 11 Replies
- 1054 Views
Last post by robin1731
- 14 Replies
- 995 Views
Last post by Lowrider Bud
