Adding some horses...
- evilratwing
- My Album: http://www.photobucket.com/evil03ratwing
Re: Adding some horses...
Has anyone got any experience with Web Cams in their 'wing? Any real dyno numbers?
They're out there...
http://www.webcamshafts.com/index_blank ... earch.html
And they're not cheap.
$385 and it's just a regrind. Same .380 max lift, too.
The bike is essentially just another bike... The pilot is CRAZY.
Whargoul - Murdered out 1978 GL1000 - Engine KaBOOM.
Cherry Cough Syrup - 2009 Suzuki M90 - 3,300 miles.
- gregforesi
I have Web cams in my Vulcan. No dyno numbers but it runs stronger than stock. They moved the power band up though.
I called one of the regrind companies (might have been Megacycle) and there grind moved the power band up high as well. "Not advised for street use" is what I was told. That may just be an idle issue.
2006 GL1800 (Brutus Maximus)
No, it's probably just a low end performance issue. My race bikes will idle for a long time. Lumpy, but idle. Depending on how lobes and duration are ground on to the cam you can lose a lot of low end power. Even midrange can go away. So you are ridingthe bike at higher RPM all the time. This of course is hard on the crank, rods, bearings. See where this is going?gregforesi wrote:snip.......... "Not advised for street use" is what I was told. That may just be an idle issue.
The way the center lines are ground also makes a difference. Thats the bad part about a single cam engine. On dual cams you can move both cams around. Which means you can move the powerband around. With a single cam you have to specify when it is ground. So you better be right the first time.
- Irishman1
C'mon sunny, ride in the rain! Nothing puts a smile on your face better when you need one, and I've needed one lately. Rain gear and I try to ride every day.
In the garage:
1975 Honda gl1000 sulfur yellow( my first!) NGW BOTM February 2020
1975 Honda gl1000 red (Ruth's free bike) NGW BOTM January 2017
1975 honda gl1000 red. Eariest of my 75's 2/75 date
1975 Honda gl1000 blue green 5/75
1975 Honda gl1000 blue green 3/75
1975 Honda gl1000 blue green 4/75
1976 Honda gl1000 sulfur yellow
1977 honda gl1000 red black, Ian's next bike
1976 Honda gl1000 red next restoration
1975 Honda cb750 rebuilding soon!
1975 Honda gl1000 2/75 blue/green
1978 Honda cb750f super sport
1979 Honda cb750f super sport
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
"I really need a BIGGER garage!!"
"I got a bigger garage!!!!
" ride'm, don't hide'm!!!
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- hoganJr
Robin, can you briefly explain that statement, please?robin1731 wrote:snip... One other thing. On the street torque is much more important the horse power. Especially on a bike/rider combo over 750-800lbs. So now you start all over.
HoganJr
1991 GL1500
hoganJr wrote:Robin, can you briefly explain that statement, please?robin1731 wrote:snip... One other thing. On the street torque is much more important the horse power. Especially on a bike/rider combo over 750-800lbs. So now you start all over.
HoganJr
Torque is what moves you. So the more torque you at lower rpm the quicker you can accelerate. More useful on the street. Horsepower is made more in the upper RPM range. Try to make too much HP and you loose torque down at the lower RPM. Right where you need it the most on the street.
- Ezrider
the biggest cheap bump probably comes from making sure your bike is running properly carb sync tune up ect.
GL1100 Chop
I agree with that one 100%.Ezrider wrote:the biggest cheap bump probably comes from making sure your bike is running properly carb sync tune up ect.
Also, power to weight makes an impact. (Go on a diet )
