Brake Caliper Rebuild Kits
- djoyner
Can anyone recommend a reputable vendor for front and rear brake caliper rebuild kits (seals, dustcaps) for a '78 GL1000?
My rear brakes stick sometimes, so I figured a may as well rebuild them all at the same time.
Thanks.
Thanks.
D J
Visit me at http://www.dennisjoyner.net
'78 GL1000
'82 GL1100I
'85 GL1200I
'95 GL1500I
'06 VTX 1300S
'06 GL1800
'78 GL1000
'82 GL1100I
'85 GL1200I
'95 GL1500I
'06 VTX 1300S
'06 GL1800
- AussieGold
Re: Brake Caliper Rebuild Kits
Georgefix an ebay vendor. excellent service and price. i had to buy the rear master kit for my 75 , from another vendor. genuine Honda . he had all but that one.
Mentor to all self appointed (and genuine) GURUS.
An LTD is........it just is.
For a sticking rear make sure to check the pedal. The sleeve of the pedal gets rust between it and the frame and it likes to bind up. Pretty easy job to remove and clean up and lube up on a 1000.
- Sagebrush
Also the tiny pressure relief hole in the master being plugged up, a common problem, can cause your symptoms. The next time it freezes up open the bleeder a smidgen to relieve the pressure in the caliper and see if that frees your brake. If it does then the problem is in the master.
Sagebrush wrote:Also the tiny pressure relief hole in the master being plugged up, a common problem, can cause your symptoms. The next time it freezes up open the bleeder a smidgen to relieve the pressure in the caliper and see if that frees your brake. If it does then the problem is in the master.
Thats a good possibility. But degraded brake lines can also be the cause.
- todd54219
http://www.siriusconinc.com/
Try here. I have used them with no issues. Also check out what the others have posted.
Todd
Todd
Todd54219 - Common sense is not so common anymore
1976 Yellow GL1000
1966 White Honda CA95 (Baby Dream) under restoration - Done and sold
1976 Yellow GL1000
- djoyner
AussieGold, thanks for the tip on Georgefix on ebay.AussieGold wrote:Georgefix an ebay vendor. excellent service and price. i had to buy the rear master kit for my 75 , from another vendor. genuine Honda . he had all but that one.
Thanks Whiskerfish, the pedal is not sticking, but thanks for the tip.Whiskerfish wrote:For a sticking rear make sure to check the pedal. The sleeve of the pedal gets rust between it and the frame and it likes to bind up. Pretty easy job to remove and clean up and lube up on a 1000.
Thanks Sagebrush, when I crack the bleeder valve, the brakes still won't release immediately.Sagebrush wrote:Also the tiny pressure relief hole in the master being plugged up, a common problem, can cause your symptoms. The next time it freezes up open the bleeder a smidgen to relieve the pressure in the caliper and see if that frees your brake. If it does then the problem is in the master.
todd54219 wrote:http://www.siriusconinc.com/
Todd
Thanks Todd.
D J
'78 GL1000
'82 GL1100I
'85 GL1200I
'95 GL1500I
'06 VTX 1300S
'06 GL1800
'78 GL1000
'82 GL1100I
'85 GL1200I
'95 GL1500I
'06 VTX 1300S
'06 GL1800
- Pooch
Thanks to tips and pictures on this forum i was able to clean that spooge hole. I never would have seen it just looking down the bore, so make sure you locate it, it's hard to see.
76 GL1000
- GL1-242
Still get the piston seal from the dealer here. You might have to outsource the dust boot. I don't think it is still available at the dealer.
Paul
Paul
84 GL1200 STD
75 GL1000 #202
75 GL1000 (AKA, GL1-242)(AKA, Flipper)
76 LTD
76/77 CB750F
Bultaco's = 121, 152, 167, 188
75 GL1000 #202
76 LTD
76/77 CB750F
- tlbranth
By far the best prices on K&L kits are here: http://www.qualitycycleparts.com/ and he only charges a few bucks for shipping.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1975 GL1000
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
- 6 Replies
- 203 Views
Last post by JBz
- 10 Replies
- 333 Views
Last post by TheWheel
- 10 Replies
- 536 Views
Last post by SoyBoySigh
- 23 Replies
- 943 Views
Last post by DUGG
