I can't seem to find a new replacement online.
Seems everyone sells them for the '76 & '77.
Looks like the electrical connection locking tab on the "Emgo 40-15820" is different, but everything else seems the same.
Anyone have luck finding one for the '75, or made the later model work?
Ignition switch for a '75
- wog
- Emgo 40-15820 ign switch.jpg (2.83 KiB) Viewed 253 times
- roncar
Re: Ignition switch for a '75
What is wrong with the one you have now?
- wog
I figured out why it wouldn't turn
- ign switch broken.jpg (126.78 KiB) Viewed 248 times
- roncar
Bring it when you pick up the frame, and we'll make one work keyed the same as your other locks (as long as the 5 number key code starts with 7, 8, 9, or 0.)
- wog
You're the man Ron!
key code starts with 0
- wog
I tried the switch from one of my '79s.
No sparks and I didn't blow up my shop!!!
It is a 6-terminal style but has the same clip as the Emgo, which I ordered from Amazon. Less then $14!
The '75 only has 5 terminals, so the extra on the later models must be for the accessory key position.
- roncar
Yes, it is for the accessory position. Also some wires have to be moved as the pinout on the two types are not the same.wog wrote:The '75 only has 5 terminals, so the extra on the later models must be for the accessory key position.
Look at this http://www.ngwclub.com/forum/viewtopic. ... 802#p92802
and this http://www.ngwclub.com/forum/viewtopic. ... 49#p153449
This, of course, will make you one of them 'damn' PO's.
- wog
Thanks for the links. I won't change any wires as the Emgo switch should be later next week.roncar wrote: This, of course, will make you one of them 'damn' PO's.
Haven't changed the belts, etc yet so I didn't try to crank it, just lights and horn.
Note to member Lucien Harpress, still can't get the air horns to work. But they're still yours when I remove 'em.
Don't worry too much about me becoming a PO, as I never seem to sell any bikes!
- 13 Replies
- 1408 Views
Last post by Mojogameplay
- 12 Replies
- 1243 Views
Last post by jdvorchak
- 383 Views
Last post by brianinpa
- 351 Views
Last post by sphen
