Electric fuel pump
Electric fuel pump
Hey all,
I am still building up my 77 project...frame should almost be done at the powder coater, but that is a different story.
I am running a dual weber setup, and it will have a touch of nitrous with it. I recently went to purchase a fuel pump from Randakk, only to find that they have been discontinued due to some factors that Randakk told me about.
This now leaves me looking for a substitute pump over the OEM, as I am not certain the stock one will have enough flow when the go fast button is hit....not to mention the amount of cranking to fill the carbs first run.
Does anyone have any suggestions to a good pump that will work well, or am I wrong, and the stock one will work fine?
Thanks for any help!
- MSGT-R
- Lady Winger
Re: Electric fuel pump
I'm still holding a Randakk kit.
I sent you a PM.
I sent you a PM.
81 Interstate: gone but never forgotten.
13 F6B
NGW Cartel
13 F6B
NGW Cartel
- pierce
- My Album: pierce
Just buy the pump yourself.
https://www.pegasusautoracing.com/produ ... RecID=8440
It is a facet pump, pn 40105.
You will have to either fabricate a bracket for it, or place it somewhere else. That was what you were really paying for with his kit. The fabricated mounts, instructions etc.
Do it yourself.
Do it yourself.
1976 GL1000
1978 Gl1000
1978 Gl1000
- gregforesi
Randall used a Facet cube pump (40171). I didn't use his mount and opted to mount it inboard on the cross-brace. A homemade cover and gasket covers the hole where the stock pump mounted.
The Webers need 3psi and the one Pierce mentions is 4.5psi so I would go with the 40171.
If you are going to run wet nitrous will you require a high pressure pump as well?
2006 GL1800 (Brutus Maximus)
Thanks for the replies to far!
The system has not been chosen yet, but it will be a wet system. Unclear yet if I will need a high pressure pump.
- pierce
- My Album: pierce
Sorry about that, must have posted the wrong model number.
Go with what Foresi posted.
1976 GL1000
1978 Gl1000
1978 Gl1000
Others have run pumps from mid 80's Honda carbureted, gl1200, most of the vf bikes.
- Millwright
Wingrider I am in the same boat myself, install new webers over the winter and a little to late for the recomended model from Randall. I am still about three weeks away from running mine, but for what it is worth I decided to get the one from cbperformance model 3193 fuel pump 3 1/2 lbs. I looked at several, and the reason that I picked this one, they recomended it off course but fom what I could tell this style is quieter. Like I said I still have about 3 weeks before startup so I am wondering if my decision will cause me grief.
Millwright
Millwright
1983 GL1100 Standard
My build thread.
My build thread.
wingrider wrote:Thanks for the replies to far!
You will have to run a wet system. Dry is for fuel injection. As long as you buy a complete kit the hight pressure fuel pump will come with it. You should "T" in to the fuel line right off of the fuel petcock. ( I thought we talked about all of this already?)
Thanks again everyone for the responses. I believe I have found a pump.
Robin, we talked a lot about the general system, (I recently poured over every message to recall everything) but never really touched on the pump....the closest we got was when you said if I got the complete kit, everything would be in it that I would need.
- Bankerdanny
Fair warning, the Facet pumps are really loud. I have one on my MGB-GT, probably the same one actually, since my twin SU's only need about 2.5lbs of pressure. I can hear it even over the substantial road noise.
'76 CB750F, parts for about 2 CB550's, '72 MGB-GT
Past bikes: '75 CB550F, 77 GL1000, '77 CB550K, '89 Yamaha FJ1200, '02 Royal Enfield Bullet 500ES, '68 Suzuki K11, '69 Yamaha YR2, '70 Honda SL175, '69 BMW R69S.
Endeavor to Persevere
- timma11
and those factors would be? anything current users of this pump should know about?wingrider wrote:<<snip>> I recently went to purchase a fuel pump from Randakk, only to find that they have been discontinued due to some factors that Randakk told me about. <<snip>>
tim
"studies have found that people with schizophrenia are about twice as likely to smoke pot as those who are unaffected"
Probably better to ask Randakk himself.timma11 wrote:and those factors would be? anything current users of this pump should know about?wingrider wrote:<<snip>> I recently went to purchase a fuel pump from Randakk, only to find that they have been discontinued due to some factors that Randakk told me about. <<snip>>
tim
I agree...I was told only general reasons why, not particular reasons.
- the chef
- Location: Odenville,Alabama. The land of dixie! (!Hell yeah!!)
On the highway to Hell!
Ride on, Ride on.. !
PREVIOUS OLD LOVES=
19?? Zundapp with 6 hp Briggs and Stratton engine Chrome tank
1971 Kawasaki H1 500 blue /white stripe
1975 Honda 750 Yellow
1980 Honda Gl 1100 Interstate Black
1982 Honda Gl 1100 Standard Black
1983 Honda Gl 1100 Aspencade Black
1981 Honda Interstate Black
1981 Honda Gl 500 Silverwing . Candy muse red
1986 Honda VT 500C red
PRESENT RIDE >1976 Honda Gl 1000 Originally red, now flat black, olive drab, primer gray.
PREVIOUS OLD LOVES=
- 10 Replies
- 873 Views
Last post by OCR
- 3 Replies
- 493 Views
Last post by Gowing
- 559 Views
Last post by Rat
- 8 Replies
- 662 Views
Last post by boogie red
- 31 Replies
- 1735 Views
Last post by CYBORG
