I've found a lot of 1100 fork seal advice but not so much on the earlier 1000's. I built up the confidence to take this on tonight. I'm assuming this also can be done with the forks in the bike, correct? I noticed under the top caps that they are allen heads. So to reiterate the process:
1. Remove front wheel, fender, and tie back the calipers.
2. Drain existing oil.
3. Loosen allen bold at the bottom of the fork.
4. Remove the cap at the top of the fork (being careful to prevent the spring from taking out an eye).
5. Slide up the dust seal.
6. Remove retainer clip above the seal
7. Remove the lower tube
8. RR the seal
9. Assemble and fill with the proper fluid and amount according to the manual.
Am I missing any steps or anything special?
'76 Fork Seal Replacement Walkthrough
- cmyoch
1976 GL1000
1978 Yamaha XS650
1984 Harley Davidson XLH1000
1969 Camaro Z28
1977 Redheaded Wife (Better move her to the top of this list)
1978 Yamaha XS650
1969 Camaro Z28
Re: '76 Fork Seal Replacement Walkthrough
that sounds about right
- 15 Replies
- 1180 Views
Last post by tomk1960
- 6 Replies
- 719 Views
Last post by Whiskerfish
- 228 Views
Last post by HILTONMOTOGUY
- 4 Replies
- 527 Views
Last post by rcmatt007
- 11 Replies
- 1188 Views
