Neutral Switch replacement
- Newby
I'm looking at a water pump job and was wondering why it is recommended to replace this switch as well?
1982 GL1100
Re: Neutral Switch replacement
Because they fail. If yours hasn't, it probably will. Some places require it to pass inspection.
On the 1100 it is in the transmission cover. Easy to get too since you already have it off to do the water pump. But if your's has been working well it's a toss up whether to do it or not.Newby wrote:I'm looking at a water pump job and was wondering why it is recommended to replace this switch as well?
i'm not aware of mass failures on the 1100 neutral switch. but tend not to fix things that arn't broke
- JBz
If its working leave it alone. Looks like you have a 82. Early 1100s have it like the 1000s. JB
- Newby
Looks like the other end of it is almost impossible to get to, any advice?
1982 GL1100
well.... hmmmmm failure..... yeah.... wait till it happens
My mechanic says he can change the neutral switch by loosening up the motor mounts and slightly moving the engine.
He states about 2-3 hours of work without the part cost.
I don't have mine working but getting into neutral is pretty easy so I don't need the light, just pull in the clutch for starting.
But I'm in a warm weather climate....................
1976 GL1000
- Sagebrush
Not on an 82 he can't. The 80-81GL1100s are like the GL1000s the neutral switch is located on the right lower side of the engine behind the frame. On the 82-83 the neutral switch is a completely different design not prone to failure like the earlier models. Its location is in the transmission cover and cannot be replaced without removing the cover. You will be removing the cover in order to replace the water pump but unless the neutral switch is giving you problems I would not replace it.cob wrote:My mechanic says he can change the neutral switch by loosening up the motor mounts and slightly moving the engine.
I am glad he thinks it is that easy.... make him swear on a stack of holy books that he won't charge you any more
Sorry,the part "I SAID"was easy was pulling in the clutch to put it into neutral for stating( I have a 1976), I
never suggested changing the switch was easy or cheap( hence mine is not fixed).
1976 GL1000
- 11 Replies
- 1194 Views
Last post by Sidecar Bob
- 7 Replies
- 868 Views
Last post by OldRider2
- 17 Replies
- 1359 Views
Last post by tlbranth
- 484 Views
Last post by BikeMaine
- 6 Replies
- 344 Views
Last post by RB
