I did a search but so far haven't come up with the answer. so my apologies if its in here somewhere.
Have the heads off and replaced the water pump. oriented the neutral switch just as shown in the how to in the shop talk section. put the front cover back on and assumed with the bike in neutral the light should come on. I didn't want to have it all together and find out it wasn't working. I don't recall for sure when I took it apart if it was working but i think it was?? so turned on the key but the neutral light doesn't come on. If it's installed right it should? The bike is a 1983 Interstate.
neutral switch not coming on after replacing water pump
- jethro1954
1980 Honda Goldwing interstate - acquired 11/19/17
1985 Honda Magna V65 - to go from here to there FAST
1986 Pontiac Fiero with a supercharged 3800 GTP motor
1983 Honda Goldwing Interstate - sold
1979 Honda Goldwing with Sportster mufflers - sold
1978 Yamaha XS1100 - Sold
1983 Honda Goldwing interstate - sold
1986 Honda Goldwing SEi - sold
- Sagebrush
Re: neutral switch not coming on after replacing water pump
If its installed incorrectly it will come on in 4th gear. You did hook up the neutral switch wiring to the harness, right?
- jethro1954
I didn't disconnect from the harness when I took it apart. Rechecked this morning and it's connected to the harness and was not loose. sounds like I need to take the front cover off and recheck what I did inside.
- jethro1954
oops, comes on in 2nd gear. I'm just a little off? switch had moved on me during reassembly. now works the way it's supposed to.
- 7 Replies
- 868 Views
Last post by OldRider2
- 7 Replies
- 804 Views
Last post by gregforesi
- 186 Views
Last post by Yellowjacket
- 17 Replies
- 1360 Views
Last post by tlbranth
- 484 Views
Last post by BikeMaine
