Thermo fan switch
Re: Thermo fan switch
remove the plug from the switch short across the two terminals, and with the key on, the fan should come on, if everything else in the system is working. if the fan doesn't come on, you have another problem. let me know if i can help
- Wingerinsandiego
Thanks, Cyborg we'll try tomorrow and let u know!
1976 LTD
1985 LTD (SOLD) To support my naked obsession!!
I don't want a nickel, just want to ride my motorcycle!
- Wingerinsandiego
Cyborg; Once I found t)synched the carbs while I was waiting for her to get hot enough to trip the fan. Just past the mid point I felt a nice breeze on the left side (sitting on bike). Looked down and WALLA the fan was running!!!! What a rush. One less thing to worry about. Now I notice gas and grease weeping from the fuel pump. I think I will try to replace it with an old 1200 electric pump from my 85 LTD and see it I can get it to work. Anyone had any success with this? Need to figure out how to mount and wire it up so it is not running all the time. Any help or schematics would be very helpful. Am currently having the same discussion on the Goldwing Doc site. Thanks Cyborg for your help.
1976 LTD
Wingerinsandiego wrote:Cyborg; Once I found t)synched the carbs while I was waiting for her to get hot enough to trip the fan. Just past the mid point I felt a nice breeze on the left side (sitting on bike). Looked down and WALLA the fan was running!!!! What a rush. One less thing to worry about. Now I notice gas and grease weeping from the fuel pump. I think I will try to replace it with an old 1200 electric pump from my 85 LTD and see it I can get it to work. Anyone had any success with this? Need to figure out how to mount and wire it up so it is not running all the time. Any help or schematics would be very helpful. Am currently having the same discussion on the Goldwing Doc site. Thanks Cyborg for your help.
The 85 LTD is fuel injected right? How much fuel pressure does that pump have? It may be way too much for carbs. You could add a regulator to it.
- Wingerinsandiego
You r correct; it is a high pressure pump with banjo bolts. May have to ge one off a carbed 1200. Thanks
1976 LTD
You can also get one from most any auto parts store. Aftermarket ones work well, just make sure the pressure is correct
- roncar
Yeah, LTD fuel pumps have a 'little' too much pressure for carbs.
- 1200Lfuelpress.jpg (72.25 KiB) Viewed 333 times
- 4508 Views
Last post by UK_Andy
- 15 Replies
- 1418 Views
Last post by pidjones
- 9 Replies
- 637 Views
Last post by Sidecar Bob
- 8 Replies
- 494 Views
Last post by Don R
