Head Bolts
mhild
Head Bolts
Post by mhild »
My memory ain't what it used to be. Just want to make sure the two longer 10mm head bolts go into the top left and top right corners, the same location as the locating dowels? lolol
1976 GL1000 LTD
Re: Head Bolts
correct
Oldewing
Secretary
Secretary
Re: Head Bolts
Post by Oldewing »
Yep what he said.
SnoBrdr
Re: Head Bolts
Post by SnoBrdr »
mhild wrote:My memory ain't what it used to be. Just want to make sure the two longer 10mm head bolts go into the top left and top right corners, the same location as the locating dowels? lolol
I was always told, with car at least, not to reuse head bolts.
Thoughts ?
78 GL1000 Original Owner 131k
Oldewing
Secretary
Secretary
Re: Head Bolts
Post by Oldewing »
These ones are old Skool, reuse is OK.
Newer ones (say after 1995, not so much). Don't forget to lube the threads and under the washer anim-cheers1
Re: Head Bolts
Oldewing wrote:These ones are old Skool, reuse is OK.
This^^^^^^^^^^^^^^, and even on older cars you reused the head bolts. The one time use bolts haven't been around all that long.
Gowing
Re: Head Bolts
Post by Gowing »
When I did my heads last month I had the same question mhid,
I tried to put them in a pattern after pulling them but when it was time to
Instal, of course they were mixed up. But when I took a close look at the block and head
I figured it out also. Good luck on seal up.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
jdvorchak
Re: Head Bolts
Post by jdvorchak »
The old one time use were call "torque to yield" and would actually stretch when torqued to spec. Only ever saw them on Chrysler products but probably used elsewhere.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
