gl1100 regulator in a 78 gl1000 black sense wire
- JBz
I realize there are other options but using what I got im installing a gl1100 regulator on my 78. . Can I get some info on where to hookup the blacksensor wire on the 1100 regulator to the 1000 wiring. Can any fused switched hot wire be a place like maybe the rear brake light switch work or back to black hot wire off the original regulator plug????????. Thanks JB
- rod willis
Re: gl1100 regulator in a 78 gl1000 black sense wire
I put one on my 75 and all I did was to run a wire from the black wire back to
the 1000 reg. plug and use the power at that point and then I taped it up
Rod
Rod
rod willis
1976 GL1000
1976 GL1000
- JBz
Hi Rod. That's exactly what I did and appears to be working fine.......... Thanks ........JB
- rod willis
- 22 Replies
- 1141 Views
Last post by mcgovern61
- 1 Replies
- 131 Views
Last post by ericheath
- 6 Replies
- 317 Views
Last post by olchris
- 9 Replies
- 368 Views
Last post by Easter
