REFINISHING OLD CHROME
My timing belt covers are really bad looking and was wondering what methods you have used to remove the old chrome. I will probably just paint them. I did a web search and there seems to be many ways to do this and maybe some have been tried by forum members. Here is a list of the ones that I'm considering.
1. Cola soak overnight 2. Bleach soak 3. Break fluid wipe 4. Over cleaner
- 20140210_091145_resized.jpg (62.13 KiB) Viewed 603 times
1977 GL1000
1998 Valyrie GL1500
1998 Valyrie GL1500
Re: REFINISHING OLD CHROME
none of the above if it is real chrome. Only reverse electrolysis removes chrome.
- Sagebrush
Are they chrome or are you just assuming they are? OEM covers were clear coated aluminum and will polish nicely once the clear is removed. There are quite a few after market chrome covers out there though and by now the chrome is usually flaking from the aluminum base. There have been a few attempts to clean up the chrome ones but its very difficult to remove all the old chrome and any left on will just flake off in the future and will generally degrade any kind of paint job you attempt.
Any Walmart carries "aircraft stripper." It's the snizz. Less expensive in the long run than the other methods you've listed. Here it's around $7 a can. Spray it on, wait a few minutes, blow it off with and air hose. O'reily's and the like sell a different brand that is probably a tad better. Click on Sunnbobb's name or check out his posts on polishing aluminum in Shoptalk. It's work, but can be done. Less work is to send them to him if they're aluminum.
ericheath wrote:SNIP It's work, but can be done. Less work is to send them to him if they're aluminum.
Look here
http://www.ngwclub.com/forum/viewtopic.php?f=6&t=44501
Sure looks like chrome flaking off to me! Shiny mirror like flakes.Sagebrush wrote:Are they chrome or are you just assuming they are? OEM covers were clear coated aluminum and will polish nicely once the clear is removed. There are quite a few after market chrome covers out there though and by now the chrome is usually flaking from the aluminum base. There have been a few attempts to clean up the chrome ones but its very difficult to remove all the old chrome and any left on will just flake off in the future and will generally degrade any kind of paint job you attempt.
1977 GL1000
1998 Valyrie GL1500
1998 Valyrie GL1500
- delling3
If it is flaking then it likely is chrome, and the covers are likely aftermarket. The stock covers came from the factory in polished/clearcoated aluminum as previously mentioned. They are available relatively cheaply on ebay. If you want the stock look, I would suggest starting there. If not, paint or powdercoating is an option.
The tops on my carbs were chromed. I sandblasted them and used hammerite paint for them. I had my valve covers and timing belt covers ceramic coated with a high-lustre silver ceramic. I went this route because I didn't want to worry about polished aluminum.
delling3
1979 Yamaha XS750SF
Previous:
2006 Kawasaki Concours: Sold
1979 Yamaha XS750SF
Previous:
- duke182
Sand blast and then sand sand and sand some more. Then sand and prime and spot fill imperfections. Sand a little more reprime wetsand then topcoat witj chosen color.
After clearcoat sand(cut) and buff.
After a few weeks polish again then wax.
That should give you some of the best looking painted covers in wingdom.
Goodluck whatever you decide
1984 1200 standard
click pic to see my gallery
vote in my poll
1984 1200 standard
vote in my poll
An industrial sand blaster can do a decent job. And works well enough to paint/powder coat over it. But like Sunnbobb said the only way to really remove chrome is to take it a chrome palter and have them remove it. Under the chrome is copper and nickel plating. So that needs to come off too.
- Norbert R
Agreed. I had one chrome valve cover that I sent to an electroplater - they used acid/chemicals to remove all the plating. Got it back amazingly clean, not the slightest hint of any residual plating. It was a nice uniform matt finish, extremely smooth, with made this the easiest of all my ali parts to polish as a result. Dirt cheap too, and no textured finish like you'd get from blasting.robin1731 wrote:An industrial sand blaster can do a decent job. And works well enough to paint/powder coat over it. But like Sunnbobb said the only way to really remove chrome is to take it a chrome palter and have them remove it. Under the chrome is copper and nickel plating. So that needs to come off too.
We won't touch chromed parts, sorry. As for having the chrome removed, it is much cheaper to just buy some used covers and polish them. Bin the chromed ones.
agreedsunnbobb wrote:We won't touch chromed parts, sorry. As for having the chrome removed, it is much cheaper to just buy some used covers and polish them. Bin the chromed ones.
rcmatt007 wrote:agreedsunnbobb wrote:We won't touch chromed parts, sorry. As for having the chrome removed, it is much cheaper to just buy some used covers and polish them. Bin the chromed ones.
Yeah, I should have added that. I did have some parts dechromed once. I didn't have any other choice with what it was. Taking the chrome off was as expensive as having them chrome plated. All the chemicals used in that industry make it pretty unfriendly to the environment. Regulations makes the price pretty high.
"chrome" plating is rather interesting. copper is layed down first to have a smooth surface, then nickle, and finally chrome.... the silvery look is the nickle
rcmatt007 wrote:"chrome" plating is rather interesting. copper is layed down first to have a smooth surface, then nickle, and finally chrome.... the silvery look is the nickle
I like stopping at the nickel part myself. Has a different look and holds up better than the chrome.
- 4 Replies
- 710 Views
Last post by tomk1960
- 15 Replies
- 598 Views
Last post by cbrianroll
- 26 Replies
- 798 Views
Last post by Placerville
