REFINISHING OLD CHROME
- Kroosa
Re: REFINISHING OLD CHROME
Sandblasting may be a harsh method. If you really want to save the covers and repaint them, you might try using beads in a media blaster before you go all the way to sand. But as was said, it is probably easier to just get used ones on Ebay.
Ken R.
2013 BMW K1600 GTL
2013 CB1100
Several 75 & 76 GL1000's,
including a few LTD's, &
other early Hondas.
2013 BMW K1600 GTL
2013 CB1100
other early Hondas.
the problem with flacking chrome is that the aluminum is way way softer than the chrome or nickle (probably even the copper, you will eat away the aluminum faster than the chrome
so.... like everyone else, get some used ones from fleabay
- tomk1960
If it's really chrome and pitting or "erupting," then I agree with replacing them. It's hard to tell from your picture what you've got there. I have successfully powder coated over chrome many times, but that's after a very thorough blasting with aluminum oxide. It also has to be in decent condition to begin with. (a relatively smooth, consistent finish) If you've ever seen the horrible pitting that occurs on chrome plated white metal, (i.e. automobile turn signal housings, etc.) it's impossible to hide them with even multiple coats.
Your picture almost looks to me like the clearcoating failed and you have oxidation now underway. That can easily be dealt with.
1986 VFR750F Interceptor
1978 Honda GL1000
1978 Honda GL1000
It's pretty rare to see copper on aluminum. It's usually just nickel and chrome.
A lot of gurus have thrown their oar in here so far be it from me to intercede but here's the bottom line. Standard Honda belt covers where never chrome, highly polished Aluminum was the best you got. So yours, whether they be professionally or unprofessionally chromed, are not standard, although you can bet that the actual belt cover is, and is of good quality metal.
There are places in every city that will take them back to the original metal, you just have to look around, and if that's too hard, just take a wire brush to them and paint 'em, there's bright Aluminum paint out there too.
It'll look good whichever way you go, if that's the only issue you have.
- taunusrainer
Another good looking alternative is sandblasting (with pretty rough corund) and then double or triple clearcoating until they are smooth and shiny. Quality clearcoat is mandatory. Cheap clearcoat will yellow quickly.
1976 GL1000 test mule
1977 GL1000 in parts, rebuild in progress
1969 Ford 17m 2.3V6
1976 Ford Cortina 2.3V6 (Propane)
1990 Mustang 5.0 7up conv.
1998 Peugeot 406 Coupe (Propane)
1969 Ford 17m 2.3V6
- 4 Replies
- 709 Views
Last post by tomk1960
- 15 Replies
- 598 Views
Last post by cbrianroll
- 26 Replies
- 798 Views
Last post by Placerville
