1985 Aspencade shut down
- FlaBoy
- Zinc Member
My 85 GL1200 Aspencade has shut down twice and I haven't found the problem. I drive it 1-2 miles, it's shuts off and won't restart. Like it has no gas. It will restart a few hours later though but shut down again. The bike sat three months but I replaced the gas with fresh. My first thought was the fuel filter which I replaced today with a universal OEM filter but shut down again. I'm out of town and have a problem finding a shop & parts to work on it since not named HD and it's age. My only other idea is a clogged gas line. Any other suggestions to look at?
John
1981 GL1100s
1985 GL1200 Aspencade
1981 GL1100s
- irishcarbomb
Re: 1985 Aspencade shut down
Try opening the fuel cap, id bet the vent is clogged.
- FlaBoy
- Zinc Member
Thanks, I'll try it later. A shop suggested blowing into the tank, lol. No way.
John
1981 GL1100s
1981 GL1100s
Is the ignition system completely shutting down? Easy to determine, before getting into fuel delivery issues.
Is there gasoline in all the fuel bowls when it quits running. Open the bowl drain screws.
Cliff (74yrs )
That bike has an electric fuel pump too. Could be having issues with it.
- FlaBoy
- Zinc Member
Thanks, the ignition is fine but I'll check the carb bowls. Chances of getting a fuel pump slim since the local dealer won't touch the bike. I'll check it too.
John
1981 GL1100s
1981 GL1100s
- RB
Try an alternative fuel source..bottle hooked up to the fuel line of the carbs tie it up so it's gravity feed and ride around.....if she runs..tank, pump, lines, or filter issue if not carbs or electrical..heat opening short in coils?? or float in carbs sticking if not EFI bike or slow to react or ???
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- rod willis
this on should have a fuel pump relay that should be under the coils
I have a 86 that was giving me some of the same problems and that
is what it turned out to be
Rod
Rod
rod willis
1976 GL1000
1976 GL1000
- FlaBoy
- Zinc Member
Thanks for the suggestion, I'll look at it too. I need it to get around.
John
John
John
1981 GL1100s
1981 GL1100s
- jdvorchak
Let's not discount the pulse gens on the front of the engine under the timing belt cover. Running for a while then after a couple of hours restarts? If there was fuel delivery problem I wouldn't expect it to restart without putting some fuel into the carbs. Although shutting down when hot is the usual symptom of the pulse generators failure.
ON the 85 the connector for the pulse gens is a 4 pin connector up under the shelter next to the regulator. Those connectors seem fragile to me and while you have the connector apart to test the pulse gens resistance (330 ohms I think but check that against the manual) be sure and clean the contacts and make sure those connector halves snap together.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- FlaBoy
- Zinc Member
Finally solved the problem. It's an ignition coil shutting down. So rb & jdvorchak got it. Many thanks to all who responded.
John
John
John
1981 GL1100s
1981 GL1100s
- 3 Replies
- 472 Views
Last post by CYBORG
- 3 Replies
- 370 Views
Last post by Track T 2411
- 9 Replies
- 1226 Views
Last post by desertrefugee
