FLUSHING COOLING SYSTEM
- Toehead
Re: FLUSHING COOLING SYSTEM
IIRC you can: The coolant tubes just pull straight out
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
Problem is the installation. If that ORing rolls when you are putting the tube back in you can not see it good with the carbs in place.
- My Album: http://s254.photobucket.com/albums/hh93/head_750/
Whiskerfish wrote:Problem is the installation. If that ORing rolls when you are putting the tube back in you can not see it good with the carbs in place.
I guess that I might as well just pull the carbs and replace all O rings and what ever I find.
1 1966 CL77 305 Scrambler
1 1967 CL77 305 Scrambler
1 1970 CB750 NO#
1 1970 CB750 Track Bike
1 1972 CB750 High Speed Highway Bike
1 1974 CB750
1 1974 CB550
1 1974 DT360A Yamaha
1 1975 CB750
1 1975 CB750F
1 1975 GL1000 #92
1 1975 GL1000
1 1977 GL1000
3 1981 CB900F
1 1983 CB1100F
And a whole bunch of parts
1 1970 CB750 NO#
1 1974 CB750
1 1974 CB550
1 1975 CB750
1 1975 CB750F
1 1975 GL1000 #92
1 1975 GL1000
1 1977 GL1000
3 1981 CB900F
1 1983 CB1100F
- chewy999
When you put the O rings on the tube, lube with a bit of washing up liquid, and push the tube in as straight as you can with a twisting action, keeping an eye on the O ring so it doesn't snag. Hard to explain better than that, but it is obvious when it is correct. Make sure the tubes are pushed fully home. I did mine on the bench and then fitted the complete assy to the engine, think it may be possible with the carbs in place, but obviously less space to work in.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- oldwings 78
Better yet, go to the hardware store and get a small tube of faucet grease. It's made for the job and you only want to do it once.
Terry
Terry
"A man who is good at making excuses is rarely good at anything else" Benjamin Franklin
"A man who will sacrifice freedom for security deserves neither" Benjamin Franklin
'78s are the best looking GLs Just ask Doc
- alwing17
- Exceptional Member
Or a small amount of Vasoline applied where the tube enters,not on the O-ring. If you go the faucet grease route,buy a 3/4" fitting brush to clean the area where the tube goes in.
1975 GL 1000 "Street Fighter"
1976 GL 1000 "Screaming Yellow Zonker"
1976 GL 1000 Sulfur Yellow x2
1981 GL 1100 "Crown Royal"
1997 GL 1500 Pearl Sapphire Black
1977 GL1000 Cirrius Blue
1977 GL 1000 Skidmark build
1976 GL 1000 Limited
2003 ST 1300 Silver Streak
(And those are just the Gold Wings! With an exception..)
Team 898...25%er...*Beverages Consumed
Team LTD...1/6th'er...* Even more beverages consumed
ngwsmilieGuys all these informational replies are what makes this a great site.
Thanks
Thanks
1 1970 CB750 NO#
1 1974 CB750
1 1974 CB550
1 1975 CB750
1 1975 CB750F
1 1975 GL1000 #92
1 1975 GL1000
1 1977 GL1000
3 1981 CB900F
1 1983 CB1100F
1 1970 CB750 NO#
1 1974 CB750
1 1974 CB550
1 1975 CB750
1 1975 CB750F
1 1975 GL1000 #92
1 1975 GL1000
1 1977 GL1000
3 1981 CB900F
1 1983 CB1100F
- 11 Replies
- 620 Views
Last post by pjlogue
- 72 Replies
- 3260 Views
Last post by 5speed
- 6 Replies
- 468 Views
Last post by ofb
- 10 Replies
- 456 Views
Last post by NotSoLilCrippseys
- 32 Replies
- 641 Views
Last post by 5speed
