79 u joint lubrication?
- goody265
- Brass Member
Recently bought a79 wing. Is there a way to grease the u joint? Thanks in advance!
all men have a life, few men truly live. 1976 GL1000
Re: 79 u joint lubrication?
No. The U joint is a sealed unit
But the splines of the shaft should be greased occasionally. Generally most folks do it when they do tire changes. The book calls for a MolyB grease.
- backyardbob
- High Mileage Guru
I lube my u-joint every couple years by immersing it in 90wt oil in a Vacuum chamber and sucking the air out, then leave it in the oil for a few days to let air pressure force the oil in.
so far so good.
so far so good.
i finally made it past the junkyard dogs!!
- pierce
- My Album: pierce
I second cyborg and whiskerfish.
Spline, yes, Moly paste. U-joint, no, it's sealed.
1976 GL1000
1978 Gl1000
1978 Gl1000
the good news is that honda beefed up the u-joints as the 1000 series progressed and you have one of the better ones
the bad news is a coupe of years ago honda obseleted the part
- Lead Member
Thanks for the replies. You people are like having my own panel of experts in my garage!
Great news. Might be pressing that starter button in a week.......
has anyone "road tested" the Freight shaker steering u joint to see if it stands up to the high rpm?
I sure hope so! But I have only about 200 miles on mine.
- 4 Replies
- 464 Views
Last post by cfairweather
- 11 Replies
- 755 Views
Last post by Shadowjack
- 6 Replies
- 336 Views
Last post by Solina Dave
- 20 Replies
- 693 Views
Last post by Old Fogey
- 2 Replies
- 515 Views
Last post by tlbranth
