79 u joint lubrication?
goody265
Brass Member
Brass Member
Post by goody265 »
Recently bought a79 wing. Is there a way to grease the u joint? Thanks in advance!
all men have a life, few men truly live. 1976 GL1000
Re: 79 u joint lubrication?
No. The U joint is a sealed unit
But the splines of the shaft should be greased occasionally. Generally most folks do it when they do tire changes. The book calls for a MolyB grease.
backyardbob
High Mileage Guru
Post by backyardbob »
I lube my u-joint every couple years by immersing it in 90wt oil in a Vacuum chamber and sucking the air out, then leave it in the oil for a few days to let air pressure force the oil in.
so far so good.
i finally made it past the junkyard dogs!!
pierce
My Album: pierce
Post by pierce »
I second cyborg and whiskerfish.
Spline, yes, Moly paste. U-joint, no, it's sealed.
1976 GL1000
1978 Gl1000
the good news is that honda beefed up the u-joints as the 1000 series progressed and you have one of the better ones
the bad news is a coupe of years ago honda obseleted the part
KeithS
Lead Member
Lead Member
Post by KeithS »
Thanks for the replies. You people are like having my own panel of experts in my garage!
Great news. Might be pressing that starter button in a week.......
5speed
Post by 5speed »
has anyone "road tested" the Freight shaker steering u joint to see if it stands up to the high rpm?
Shadowjack
Post by Shadowjack »
I sure hope so! But I have only about 200 miles on mine.
