When I turn on the key and hit the start button my lights just go dim. The starter doesn't even try to spin . Battery is brand new AGM and is 12 + volts. The horn is loud. any thoughts?
won't turn over
won't turn over
bum
8 wings + 1 Triumph +2 Musclecars = 1 pissed off wife !!!
Re: won't turn over
Do you hear a "Click"?? First need to check the starter solenoid. Should be mounted to the back side of the battery box.
- hmratbam
Re: won't turn over
Take the plugs out,turn off the kill switch and try again?
My Album
84 Standard ongoing project
My Album
Re: won't turn over
hmratbam wrote:Take the plugs out,turn off the kill switch and try again?
Try this. Do make sure you have the kill switch off. And don't be standing above or looking in to the spark plug holes when you hit the starter.
- Barney T Weasel
Re: won't turn over
Try jumper lead onto starter terminal (+) then direct to battery. (make sure the earth (-) is good too. If you wont turn over you have a starter motor problem. Easy to remove and service. I did mine in under a 1/2 hour. The planetary gearboxes dry out. Give it a good grease.
GL1000 '75 model Blue....heading to rat, then cafe racer then full resto...owned 33 years.
http://www.dungbeetlebiker.com/forum/forum.php
- ritalz
Re: won't turn over
Another thought is the interlock system will not let the starter engage. Try pulling the clutch leaver and hit the start button.
What bike are you working on?
- Barney T Weasel
Re: won't turn over
Just check that the engine will turn over by rocking it backwards and forward in top gear first as it may be a locked up engine. Mine had sat for 27 years and surface rust in the bore caused it to lock up. I rocked it back and forth (with oil and WD-40 in the bore) until I freed it up. It runs well now with no strip down. Just make sure the motors OK before you try my direct to starter motor deal. Good luck.
- 17 Replies
- 1100 Views
Last post by zxWIZxz
- 11 Replies
- 798 Views
Last post by Eengers
- 4 Replies
- 276 Views
Last post by Track T 2411
- 188 Views
Last post by pidjones
- 9 Replies
- 390 Views
Last post by mhild
